Have you found a bug with the forum or just want to give feedback on the site? This is the place.
#39869
James took DuffNet down because someone kept attacking the server unfortunately.
#39872
I'd make a suggestion to unpin (it's currently under Board index > Installation > 10.12 Sierra) or edit the post. That'd reduce clutter a bit.
As a side note, is there a readme document for this SierraAMD release somewhere?
I know of the PostInstall document included on dmg image, but I remember seeing a few specifics somewhere, like once having to name the partition 'macOS' with proper casing (I know that's no longer needed looking at the script).
The Tutorials subforum has a few guides, but they could be more useful and up to date, if they'd be setup as a wiki article with moderation.
#39875
The install guide for V5 tells you everything you need to install it. No need to update as the installers never change.
I got the same problem, look forward to fixing it […]
Hardware: Processor: AMD FX 8300 Graphics Card: […]
Can you help me? In my installation it gives still[…]
Hi everyone, Ok so I've "almost" instal[…]
