Have you found a bug with the forum or just want to give feedback on the site? This is the place.
by: Ackados
#13299
This might be just my internet, but on the forum page,
forum.amd-osx.com
it loads, but some buttons don't, and I can't click on links, and the cursor is always default. Not sure if this is a bug, but it could still be just my internet. :P
#13324
Hmm I've never seen an issue. Could be a cache issue. I've flushed the caches so see if it happens again.
by: Ackados
#13326
Oh, this was on Windows. I waited a bit, and rebooted my PC, and it seemed to go away after a little while.
hello everyone, I'm about to buy this motherboard:[…]
i have almost same pc. except gpu. i have rx 460.[…]
As the subject shows, i want to get some games fro[…]
ok thanks for advice, can't go to InsanelyMac I've[…]
