by: brickman7713
#50439
Hello, I'm back again. This time I have a custom machine that I want to run Mojave on. Specs below.
Mobo: Gigabyte GA-MA785GMT-UD2H (rev 1.0)
CPU: AMD Athlon II x3 440
RAM: 16GB DDR3
GPU: AMD Radeon HD 6450
I am planning on upgrading my CPU though and looking at a FX 4130 because that looks like the best one for my Mobo. So will that work? Thanks!
Anybody?
I went ahead and bought the fx-4130 and found out that even though it's listed on my motherboard cpu list is does not work with my motherboard. So I got a GA-87lmt usb3 R2 board. I was about to get the usb drive booted after fixing the appleusbhostcontroller problem but it doesn't take me to a installer. Instead it is like a recovery drive, I followed the guide at vanilla.amd-osx.com
#50827
The installer is a recovery medium. It'll download the required files during the install.
by: brickman7713
#50834
Shaneee wrote: Sun Aug 25, 2019 10:12 pm The installer is a recovery medium. It'll download the required files during the install.
Thanks I discovered the vanilla amd osx Knowledge Base and found that out. I got it installed but it rebooted after selecting my keyboard layout the first time. Trying again now.
#50836
See the comment from XLNC about that issue here, https://www.insanelymac.com/forum/topic ... nt-2658085
by: brickman7713
#50844
I tried that but it give me an error after every user command, something about eserver
Thanks to your EFI i've managed to finally put the[…]
@gbp27 , Try with this.
Use a different USB port. It's hanging on Still W[…]
Using Hackintool for USB Mapping?
Is there a downside to using Hackintool for USB ma[…]
