by: keyed__
#49645
So, I already have a working AMD hackintosh on my desktop, but now i'm wondering if it's going to be possible to install High Sierra on my laptop.
My laptop has a Ryzen 7 1200u, and a full GTX 1050 (not 1050m)
I've tried just using the same install drive I used for my deskop, and it boots into the install drive but the loading bar gets half way then stops. Do I need to begin troubleshooting or am I fighting a lost cause?
by: IOIIIO
#49688
Laptops are not worth it.
Too many issues, and that 1050 won't work, which leaves you with the iGPU which is unsupported.
@qtwhl Absolutely! I find the devs did an amazing […]
Hello, My Friends! I'm a Brazilian user, my knowl[…]
I followed the tutorial here: https://vanilla.amd[…]
Will my config work as a ryzentossh?
I have never even built a PC and i really wanna ma[…]
