#47823
Hello I want to ask if my pc specs works with the os. This will be my very first time to try out macOS. My PC specs are below.
Processor: Ryzen 2600x
GPU: Gtx 980 asus strix 4g OC
Ram: Gskill Trident Z AM4 3200mhz
Motherboard: Gigabyte Aorus M B450
Soundcard: Creative Titanium HD
First you should post what guide you followed if a[…]
when boot EFI windows bootloader(bootmgfw.efi) rea[…]
Parallels?
I tried and had problems with Parallels too. OSX […]
you just need RealtekRTL8111.kext for lan to work
