by: IOIIIO
#47465
Vega 6 won't work properly. It is not worth it.
by: Alexpm
#47468
And if i only used it for xcode you can guide for install it and later i would put a external gpu for get better performance...
I needed to much for development testing pls..
Enviado desde mi SM-N950U mediante Tapatalk
by: IOIIIO
#47476
Xcode will work. The simulators will not. Keep that in mind.
by: Alexpm
#47477
Okey bro thats fine if i buy later a egpu i can install the drivers and used it all okey right?
by: IOIIIO
#47478
Probably. Depends on how you hook it up.
Anyhow, you will probably have to install to an external USB (hard)drive. People have reported issues with the installer not seeing the internal HDD on laptops.
Should be able to just follow one of the guides over at https://kb.amd-osx.com to set it up. Remember that you are running a very unsupported configuration, so GPU performance will suffer badly.
by: Alexpm
#47479
And i have a
Amd 10-5745m
R7 egpu
It would work better?
by: IOIIIO
#47480
R7 is not being very specific. R7 what?
by: IOIIIO
#47482
That's not an eGPU. That is a dGPU on the laptop itself which is also not supported.
Hi, that sounds great. You've decided to install H[…]
Hi, I'm not sure but seems to me like your install[…]
Hi, you'd better tell us how do you prepare your b[…]
Hi, did you put your new config.plist and kexts in[…]
