by: Rapids
#46129
CPU: AMD FX-6300
MB: ASRock 760GM-HDV
RAM: 8gb DDR3
GPU: AMD Radeon RX 560 (2gb)
Am I good to dual boot? I already have the usb made.
Edit: I’d be willing to install another version if that’s easier. If you know what version is easiest for my system, please tell me.
Hi guys. I'm new here and new in this hackintoshin[…]
Help make USB Installer
Yes, ViciBox v.6 and later 6/7/8 can be successful[…]
Use only the internal GPU of the CPU because you c[…]
I understand what you tell me though I wanted to a[…]
