#46100
OS Name Microsoft Windows 10 Home
Version 10.0.18342 Build 18342
Other OS Description Not Available
System Manufacturer ASUSTeK COMPUTER INC.
System Type x64-based PC
System SKU SKU
Processor AMD A10-6800K APU with Radeon(tm) HD Graphics, 4100 Mhz, 2 Core(s), 4 Logical Processor(s)
BIOS Version/Date ASUSTeK COMPUTER INC. (Licensed from AMI) 0403, 12/24/2013
SMBIOS Version 2.7
Embedded Controller Version 255.255
BIOS Mode UEFI
Platform Role Desktop
Hardware Abstraction Layer Version = "10.0.18342.1"
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 16.0 GB
Available Physical Memory 12.0 GB
Total Virtual Memory 18.8 GB
Available Virtual Memory 13.7 GB
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not Modern Standby, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
:x :x
I updated 10.14.1 to 10.14.5 from the app store an[…]
After installing 10.14.1, the app store kept pulli[…]
try usb 2.0 Post Merged try usb 2.0 or usb 2.0[…]
INSTALLING MOJAVE
:thumbup: Post Merged :cool:
