by: dimatrox
#45257
Hi there, i'm planning to build a pc that i would like to hackintosh
I already have
Motherboard (MSI B450M PRO-VDH PLUS)
a 1TB Kingston SSD
8gb of ram, I think i'll upgrade to 16
my case and power supply
On Cpu/Gpu i'm hesitating between
Ryzen 7 2700X / 5 2600X
And RX570 or GTX1050ti
Does any of you know if i can hackintosh it, wich version, and for the CPU/GPU what are the choices that will be easier to hackintosh
(Excuse me if my english is bad)
Anyone ?
How to force install 10.14.1?
The Vanilla patch made updating so easy. No more r[…]
The guide worked perfectly for me. Thanks. Specs[…]
try this https://www.youtube.com/watch?v=Y9I-OINW[…]
I have same cpu, any tips appreciated. Firm inte[…]
