#44805
hey guys, this is my first time trying out a ryzentosh. I have a ryzen 2200g + asus ab320m-hdv motherboard coupled with 8gb of ram and would like to purchase an external card on a budget just to get high sierra or mojave running. I need it only for coding and compiling stuff that doesn't require much processing from the graphics side. Could someone point out the cheapest graphics card I could buy to get osx running. Ideally if it is under a $100-80 that would be best.
Thanks in advance
Hi guys, I'm trying to boot mac os installer and g[…]
I have successfully installed HighSierra on this b[…]
Hi Guys, whenever I try to install clover to use i[…]
Hi guys, I have been using the latest method with […]
