#42555
Mine is working just fine, and I have been using it daily.
I have not been able to get a few things working though, like the temperature sensors.
#43689
anything else ? any problems with this MB ? Thanks
what about Wifi Bluetooth and ethernet ?
#45125
34313 wrote:Mine is working just fine, and I have been using it daily.
Can you, or anyone else, post a walkthrough (Bios settings, High Sierra or Mojave install?)
Thanks!
#45431
Thanks!
I just followed the guide on this website.
If you hit any trouble following it, post here and i will help if I know the answer!
#47364
Hi,
Do you manage to get the audio working? Mine the sound is stuttering and all usb ports doesn’t seem stable. There is a periodic lag in usb.
Thanks
#47384
sorry i don't use the audio ports.
there is some weird thing about the hackintosh will only boot if the keyboard is plugged into the gen2 ports.
but apart from that, the usbs are all functioning.
nice. details on the ram ? https://www.microc[…]
Inject this kext, https://files.amd-osx.com/XLNCUS[…]
Hi All, First time long time haha, CPU: R7 1700 […]
I get this error https://photos.app.goo.gl/oR1[…]
