by: Markcucciolo
#38800
Hi, I am new in Hackintosh and instresting to installing it on my PC.
CPU: AMD Ryzen 5 1600 @3.2 GHz
MOBO: Asrock AB350M Pro4
GPU: VGA Palit GTX1050Ti 4GB Dual OC
RAM: Corsair 8GB DDR4 @ 3000MHz Vengeance LPX
Can I install Hackintosh? What should I download?
Thank you :D
by: AlGrey
#38802
Welcome,
follow this guide to install macOS : viewtopic.php?f=23&t=2948
You have a video tutorial there.
Markcucciolo liked this
Happy Holidays
Merry Christmas and happy new year Shanee and tha[…]
Can you help me ? What step did you take pre-insta[…]
Did you even try to run the script.. Because DSDT […]
Hello everyone. Today i tried to update my amdint[…]
AMD OS X Advertisements
