#37757
Loads something called enoch then text mode then amd installation.
In this it does not detect my unallocated space in disk utility to make a new partition.
Should i make an ntfs partition in windows before only ?
I guess the uefi and gui clover would have been nice if worked.
#37759
Thats V1 I linked the wrong one to you. But you can make a ntfs partition in windows then run the installer. If you want the legacy V2 here ya go:
https://drive.google.com/open?id=1-po1kq3SKKutNCvnMrDuWHxqAYcxKHpJ
#37764
ok
#37769
Norton287 wrote:
Wed Feb 14, 2018 8:45 pm
I tried this.
Same x64 exception error
And uefi boot gives black screen hang
What to do ?
#37795
What motherboard do you have?
#37797
It supports UEFI, did you enable UEFI in the bios. V2 legacy and UEFI work ok, not sure why it's loading to a black screen. The only installer you were successful with was V1, V1 would be terrible to configure for your iGPU though.
Try AMDHS V2 its a different build: viewtopic.php?f=23&t=2948
#37802
Bios is correct for booting UEFI, give AMDHS a go and see what happens.
For some reason, when extracting the archives of t[…]
Update to 10.13.6 so you can use the updated kerne[…]
Hello after formatting the hard drive I only have […]
There is no timing problems on AMD macos. CPU wi[…]
AMD OS X Advertisements
