#37726
GIGABYTE GA-AM1M-S2H motherboard
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name AMD Athlon 5150
Codename Kabini
Specification AMD Athlon(tm) 5150 APU with Radeon(tm) R3
Package Socket AM1 (721)
CPUID F.0.1
Extended CPUID 16.0
Core Stepping KB-A1
Technology 28 nm
TDP Limit 25.0 Watts
Core Speed 1596.8 MHz
Multiplier x Bus Speed 16.0 x 99.8 MHz
Stock frequency 1600 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 2-way set associative, 64-byte line size
L2 cache 2048 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Min FID 8.0x
# of P-States 5
Chipset
Northbridge AMD K16 IMC rev. 00
Southbridge AMD Kabini FCH rev. 7.2
Graphic Interface PCI-Express
PCI-E Link Width x0
PCI-E Max Link Width x0
Memory Type DDR3
Memory Size 4 GBytes
Channels Single
Memory Frequency 665.3 MHz (3:20)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 10
Cycle Time (tRAS) 24
Bank Cycle Time (tRC) 33
Uncore Frequency 798.4 MHz
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Hyundai Electronics (AD000000000000000000)
Size 4096 MBytes
Max bandwidth PC3-10700 (667 MHz)
Display adapter 0
Name AMD Radeon HD 8400 / R3 Series
Board Manufacturer GIGABYTE Technology
Memory size 512 MB
PCI device bus 0 (0x0), device 1 (0x1), function 0 (0x0)
Vendor ID 0x1002 (0x1458)
Model ID 0x9830 (0xD000)
Performance Level 0
Core clock 266.7 MHz
Memory clock 667.0 MHz
Performance Level 1
Core clock 600.0 MHz
Please let me know is it compatible and how to dual boot with windows 7 x64 on the 2nd partition.
thanks and regards
#37727
You can run SierraAMD or HighSierraAMD, HighSierraAMD Official V2 is linked in my signature. Here's the installation tutorial: viewtopic.php?f=24&t=3460
You need to look at this tutorial for you video card: viewtopic.php?f=24&t=2976
You would use Clover EFI to dual boot windows and macOS, you'd need to use a seperate HD for the macOS or partition your existing HD.
devwhatsapp liked this
#37728
Norton287 wrote:You can run SierraAMD or HighSierraAMD, HighSierraAMD Official V2 is linked in my signature. Here's the installation tutorial: viewtopic.php?f=24&t=3460
  • Downloaded
    Okay will follow and install
Norton287 wrote: You need to look at this tutorial for you video card: viewtopic.php?f=24&t=2976
The video part is post installation and booting into mac os right ?
Norton287 wrote:You would use Clover EFI to dual boot windows and macOS, you'd need to use a seperate HD for the macOS or partition your existing HD.
This also post installation and post fixing the video card. Right ? I have a 2nd partition only. No extra hdd.
Thanks
#37729
Yes video is post installation before final boot.
#37735
Boot from UEFI version that version in my signature is UEFI only
I can make a legacy installer but it will be about 6 hours to upload.
Here's the original legacy installer for V2:
https://drive.google.com/open?id=1l9GulwYuVK309jN6w8qBC8rDat7LUVnD
#37736
Hi
Before I try your above advice.
I want to tell you my HDD is in MBR parition style.
Is that a problem ?
Just want to add this also
When booting from uefi and clicking on boot from mac os sierra it goes into black screen and stuck. how long should i wait ?
Regards
#37737
MBR should be ok, no efi will get made but you can install clover to the hard drive. UEFI shouldn't boot to a black screen, could be video, go to Options - Configs and choose InjectATI then return and boot and see if that makes a difference.
#37739
Ok
The sources are listed for Mojave here: https://op[…]
I'm using an Asus B450M Tuf gaming plus with a 270[…]
random ketbord freeze
Since when I updated to 10.13.16 I have continuos […]
How to Install ENOCH video)
Struggled forever getting this to work doing it al[…]
AMD OS X Advertisements
