by: flecky2006
#37647
296/5000
Hello and good morning,
I am a young man from Germany and would like to know if my system is compatible?
Board.: A320M-DGS
CPU.: Ryzen 7 1700X
Ram .: 2 * 8 GB GSkill
GPU .: GTX 1080 Strix
M.2.: Samsung 960 Evo
With which installer do I have the best options?
Doesn't work.. I added my config.plist to pastebin[…]
Hey guys ! I updated from High Sierra (10.13.6) to[…]
Having same issue with my build
After I update to high sierra 10.13.6 i install […]
