by: owlnotebook
#37593
I know probably nobody has these chips yet because they were released today.
Do you think the kernels will work for Vega integrated graphics?
by: Norton287
#37605
Your best bet is to PM AlGrey and ask, he's the video guru
by: jahod
#37654
Any luck with your question? Thinking of buying that APU...
by: AlGrey
#37661
I have no idea and I don't have access to one to test it.
I don't think you will get acceleration as there are no drivers available for mobile AMD GPUs using the GCN 5.0 architecture.
AMD10000Controller [Iriri, Japura, Kamarang]:
0x68601002 Radeon Instinct MI25
0x68671002 ??
0x687F1002 Vega 10 XT [Radeon RX Vega 56/64 all variants]
0x68631002 Vega 10 XTX [Radeon Vega Frontier Edition]
0x68641002 ??
by: jahod
#37701
It means it will never work, or we just have to wait..?
Then lets just buy a 1st gen ryzen and buy a card, when its reasonable?
by: AlGrey
#37770
wait.. and hope the next MacBook Pro includes an intel processor with Vega graphics
jahod liked this
#39416
There's no acceleration from the iGPU but the CPU works well. I've got a couple ideas for the iGPU though. I'll test when I've got time.
vinhbaoabc liked this
by: vinhbaoabc
#39592
Shaneee wrote:
Wed Apr 11, 2018 11:09 pm
Have you any test with this ?
For some reason, when extracting the archives of t[…]
Update to 10.13.6 so you can use the updated kerne[…]
Hello after formatting the hard drive I only have […]
There is no timing problems on AMD macos. CPU wi[…]
AMD OS X Advertisements
