by: Ben Dover
#54709
CPU: AMD FX 8320E
GPU: NVIDIA GTX 960 4GB
Mainboard: ASUS M5A78L-M LX3
RAM: 16GB DDR3 1600MHz
SSD: Itenso 256GB
I hope this will work.
by: Olaf Neumann
#54713
Hello Ben Dover,
with your Grafikkarte you can install until HighSierra Vanilla or with mod. AMD Kernel.
See here for your Grafikkarte:
https://khronokernel-3.gitbook.io/catal ... nvidia-gpu
Maxwell Series (GTX 9xx, 745, 750 and ti variant) Highest Supported OS: High Sierra 10.13.6
Same idea as Pascal, though the naming scheme is a bit odd as the GTX 745, 750 and 750ti are all Maxwell based even though they’re being marketed with the Kepler line so be wary when buying
Supported cards:
GTX Titan X(GM 200 Maxwell core)
GTX 980 Ti
GTX 980
GTX 970
GTX 960
GTX 950
GTX 750 Ti
GTX 750
GTX 745
Quadro:
Quadro M6000
Quadro M5000
Quadro M4000
Quadro M2000
Quadro K220
Quadro K1200
Quadro K620
NVS 510
Needed kexts:
Nvidia’s Web drivers
Lilu.kext
WhateverGreen.kext
Extras:
shikigva=40 boot flag: Swaps boardID to iMac14,2 for better Nvidia Support and whitelists patches
NvidiaWeb property: Forces nvda_drv=1 on each boot, required for systems with non-native NVRAM(EmuVariableUEFI)
Regards, Olaf Neumann
Ben Dover liked this
You should not need the DSDT.aml nor the SSDT-EC.d[…]
Matx board? Sleep and wake is fine?)
Speak to XLNC on the Discord. It's a non Zen issue[…]
Help booting Mojave installer
OpenCore supports all version of 10.13, 10.14 and[…]
