#44109
Hello Forum,
I downloaded "AMD OS X V2.dmg" und burned it with TransMac.
So far no problem.
Then I started the USB Stick and began with the Install.
Everthing okay, and then I wanted to start the PostInstall, but the
DMG-Image seens not to have the PostInstall Folder.
Where can I get it?
Regards, Olaf Neumann from Germany
System: Mojave 10.14.4 Motherboard: Gigabyte Aoru[…]
how did you get the bluetooth and wifi working? it[…]
stuck at root device UUID is....
amd 1700 msi b350 rx590 can use this config.pli[…]
Thanks! I'll try it later!
