#43087
Download Files:
https://www.dropbox.com/s/pnnhmwrpn9toi8i/Video_Update_Files.zip?dl=0
https://www.shirt-pocket.com/SuperDuper/SuperDuperDescription.html
tikizondo94, serjnenov, adidas and 4 others liked this
by: tikizondo94
#43088
Are we able to finally update to 10.13.6?
#43090
Yeah Apple released the source. I've updated my system :thumbup:
bernek liked this
by: bernek
#43098
Shaneee wrote:Yeah Apple released the source. I've updated my system :thumbup:
A small tutorial for AMD OSX noobs ? :P
#43099
This is a tutorial on how to update...
by: bernek
#43100
Sorry my bad didn't see the huge video :) is SuperDopper only for backup purposes ?
#43101
bernek wrote:Sorry my bad didn't see the huge video :) is SuperDopper only for backup purposes ?
Yeah it'll backup the install so it can be booted on either another partition or drive. You need this to boot to so you can install the update to the main drive and replace a couple files.
bernek liked this
by: bernek
#43102
Shaneee wrote:
Thu Oct 04, 2018 8:56 am
Yeah I've understood the principle now ! Sorry for my questions ... Do you think the clone can be on an external USB3 drive ? Or I better make a partition on one of the internal drives ?
I think macOS could cause problems (hackintosh mode) to boot from USB External drive ... I know on the real thing there are no problems booting from USB.
#43104
As long as you've got fully working USB it should be fine but remember even with USB 3.0 it won't be as snappy than on a HDD/SSD.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 12
Good day. I have a problem - nothing happens when […]
Hi Guys. New here. I've been wanting to install OS[…]
ryzen 2400G hackintoshable ?!
Yes Is the Built-in Graphic card working?
Ryzen 2400G Hackintosh Compatible?
Integrated GPU sort of works but not properly. I[…]
AMD OS X Advertisements
