• How to install 10.11.6 Update
  • Tutorials for the installation and post install.
#4272 by Shaneee
Mon Jul 18, 2016 9:07 pm
Don't update with the App Store
First you're going to need to download some files.
You'll need the 10.11.6 Combo Update from here,
You'll also need the latest kernel from here,
And RepairPermissions from here,
Now first of all you're going to want to backup any modified Apple kexts for example AppleHDA or AppleGraphicsPowerManagement as they will be replaced. Just copy them into a folder on your desktop.
Now you can install the 10.11.6 Combo Update. Once it's finished don't restart your machine as the kernel won't boot your system.
From here copy the new kernel you downloaded into /System/Library/Kernels replacing the one that's there.
Now navigate to /System/Library/Caches and delete the folder named com.apple.kext.caches
Now go to /System/Library/PrelinkedKernels and delete the file prelinkedkernel
Once that's done copy the System.kext that came with the kernel and any kexts you backed up and copy them to /System/Library/Extensions/
Now you'll need to repair the permissions of those kexts so open up Terminal and extract the RepairPermissions tool to your desktop and enter the following commands,
sudo su
Enter your password then drag the RepairPermissions file onto the terminal window and add a forwardslash so it looks similar to this,
sh-3.2# /Users/shaneee/Desktop/RepairPermissions /
Press Enter and it will repair the permissions. Now enter the following command,
kextcache -u /
This should rebuild the prelinkedkernel with the AMD kernel and you'r kexts. If successful you can now reboot.
skadush liked this
This topic has 76 replies
