#34932
vitorlage, Thraller King, tuobraun and 5 others liked this
by: zzmadd
#35134
I get this when I boot after adding the apfs driver
is it correct, can I hide it?
#35657
Yeah that's normal. There's a modified version of the efi file somewhere. I'll try find it.
by: Norton287
#37722
If you download V2 from my signature you already have it, just need to at the end of the install use Clover Configurator to mount the EFI of the USB and copy it to your Hard Drives EFI/Clover/drivers64UEFI. Here's the video on how to mount the EFIs: viewtopic.php?f=24&t=3538
by: Krlooh
#43605
WBloco wrote:Where I can find the apfs.efi file?
On your USB drive in EFI/Clover/driver64UEFI folder
Sorry, but the video link is down. Can you reupload? or.. Can tell me someone what must I do with apfs.efi file?
Thanks! :thumbup:
Ramir liked this
Good day. I have a problem - nothing happens when […]
Hi Guys. New here. I've been wanting to install OS[…]
ryzen 2400G hackintoshable ?!
Yes Is the Built-in Graphic card working?
Ryzen 2400G Hackintosh Compatible?
Integrated GPU sort of works but not properly. I[…]
AMD OS X Advertisements
