by: ardynosaurus
#34006
Norton287 wrote:
Wed Dec 06, 2017 2:27 pm
You don't want Optiofix2drv.efi you want the optiofixdrv.efi
ok, I'll reinstall clover,
after that, do I just reboot or are there any step else?
by: Norton287
#34008
You need to copy the clover files from the root of your harddrive to your EFI folder and overwrite clover and rename config_RADVESA.plist to config.plist. Then you need to follow this guide to setting up your video card: viewtopic.php?f=24&t=2976
by: ardynosaurus
#34009
Norton287 wrote:
Wed Dec 06, 2017 2:36 pm
I can't find config_RADVESA.plist
by: Norton287
#34010
You didn't install V5.2, Use config_InjectAMD.plist and rename it config.plist
You later want to edit it with you device ID in Devices section of Clover Configurator
by: ardynosaurus
#34075
Norton287 wrote:
Wed Dec 06, 2017 3:01 pm
I just realize that I don't have EFI partition...
are there any way to create EFI partition? or should I reinstall macOS?
https://www.dropbox.com/s/jqafipusmnjwn ... M.png?dl=0
by: Norton287
#34079
can't create one, you needed to during install create your partition and format it GUID with extended journaled.
by: ardynosaurus
#34137
Norton287 wrote:
Thu Dec 07, 2017 2:20 pm
I've reinstalled macOS and now I have EFI partition, but I can't mount EFI partition in clover configuration, how to fix it?
by: Norton287
#34138
you should just be able to see your hard drive and click mount from the Mount EFI tab
You can also try EFI Mounter, I've never used it before.
by: Norton287
#34148
Reinstall clover UEFI over your copy to put the correct GPT files in place to boot.
  • 1
  • 11
  • 12
  • 13
  • 14
  • 15
  • 20
[email protected] All USB ports work, :thumbup: but[…]
Hello. After 10.13.6 update, again black screen. I[…]
@mrtioiyf , right TeraScale 3 gpus are not suppo[…]
HI, I was using Gtx 970 with 1700x. But, its g[…]
