by: LinggaMG
#33892
I try to reinstall macOS and confirm to complete copy EFI/Clover..
but same problem, display no signal on monitor (I use HDMI port)
but if i press keyboard, there is alert sound.
whether to try using DVI-D port?
attach my config.plist
https://www.dropbox.com/s/k0lecdezkpvzwmc/config.plist?dl=0
by: Norton287
#33893
Yes try DVI
by: Norton287
#33916
What happens when you don't boot off usb, also you need to put your hardware specs in your signature
by: Norton287
#33923
Did you install clover with UEFI settings?
by: Norton287
#33951
Yes, uncheck install in ESP
Updated Enoch installer PostInstall
by: Norton287
#34004
You don't want Optiofix2drv.efi you want the optiofixdrv.efi
  • 1
  • 10
  • 11
  • 12
  • 13
  • 14
  • 20
Hey guys, I built my first Hackintosh thanks to yo[…]
i want to buy a Intel based laptop with 16GB memor[…]
So I was able to finally find an All-in-one packag[…]
So I managed to get it to the first screen after h[…]
AMD OS X Advertisements
