by: Norton287
#28089
Restore the SierraAMD_V5 image to USB with Transmac, here is a guide written by Shaneee: http://forum.amd-osx.com/viewtopic.php?f=24&t=1213
First thing is to check your bios and make sure you're setup for UEFI booting for both hard drives and removable media, like so:
https://photos.app.goo.gl/IEJj1SS4mFR3d4jH2
Once you bios is setup correctly its time to boot the USB drive. When the Clover menu loads you want to select Boot macOS from SierraAMD to start the install. You'll be in verbose mode so you'll see a lot of text go by, it will hang at gIOScreenLockState for a couple of minutes then load the graphical installer. Click Continue, then Click Continue again to agree to the License Agreement, then click Agree.
This will take you to selecting the drive you want to install macOS to, click on Utilities from the menu like so:
https://photos.app.goo.gl/DJH24t7FB10GlCf22
Select Disk Utility from the menu. Once disk utility loads you want to select your drive on the left and the click Partition button from the top menu. This will open the disk partioning tool like so:
https://photos.app.goo.gl/CUL4kuG8IPIZrIsB3
Click the + sign to add a partition or select Your existing partition and on the right you want to choose GUID partition map and format as +HFS. Name the partition macOS to be standard. Let the partition be formatted and once complete exit Disk Utility and it should show up as available disk to select to install on, like so:
https://photos.app.goo.gl/4jGbuW85tocxvEAy2
Click Continue to start the installation. If you have your USB plugged into a USB 2 port it can take up to four hours sometimes or even overnight. Just let the install run and eventually it will finish:
https://photos.app.goo.gl/u3U0uVyoLliXFQGg1
It will now reboot and we are on to the PostInstall portion.
Post Install
Boot off the USB installer and select Boot macOS from SierraAMD. This will load the installer again, once the installer loads click Continue to get to the license agreement and then you should see the menu appear. Select Utilities from the menu and then select Terminal, like so:
https://photos.app.goo.gl/nmHZoIynx2tWkidO2
Once Terminal opens you're going to issue some commands and they are case sensitive. The first command is like so:
 cd /Volumes/SierraAMD/PostInstall and press enter
https://photos.app.goo.gl/WkfxJgu9ZmXQKJBf2
The second command is post.sh, you run it like this:
sh post.sh and press enter
https://photos.app.goo.gl/6CG43xBsJDfQQCvz1
This will prompt you for the disk Sierra is installed on, enter macOS and press enter:
https://photos.app.goo.gl/D9KoysMKoJgWMpdo2
You'll see messages go by, look for errors, when it copies the kexts there will be some verbage not to worry about. Look for messages like could not build prelinkedkernel.
https://photos.app.goo.gl/aVo1VephmzPhvZIF2
Now wait a minute and it will restart or you can click the Apple Menu and choose Restart.
Booting From The Hard Drive For The First Time
Now it's time to boot from the hard drive for the first time. Since there is no boot loader installed you will use the USB Installer to boot. When the Clover menu loads select Boot macOS from macOS and press enter. It will hang for a few minutes at gIOScreenLockState but give it time and the OS will load. Now for the setup.
Setup starts immediately on OS load, first is to select your language and click continue like so:
https://photos.app.goo.gl/WBELCHPmVT9LYy9K2
Next is selecting your keyboard, select your keyboard and click Continue like so:
https://photos.app.goo.gl/CZ2sXRW9UmgUWge52
Next is selecting how you connect to the Internet, choose your method and click Continue like so:
https://photos.app.goo.gl/cDrMA1GU1YtK9JQ72
If your network driver didn't load, you'll see the next screen, just click on the Continue like so:
https://photos.app.goo.gl/u3FXlebDKJ71AJfW2
Next it will ask you if you want to transfer information to your mac, just select No like so:
https://photos.app.goo.gl/HqisjD84mWdttzvk1
Next it will ask you if you want to enable Location Services, uncheck it and click Continue like so:
https://photos.app.goo.gl/g5i0IYKhZsgqjjgA2
Next is to select your Time Zone, on the map click on the region you're from and click Continue like so:
https://photos.app.goo.gl/Q1k3QAckDz6CpeDl1
Next it will ask you if you want to participate in Analytics, uncheck both boxes and click Continue like so:
https://photos.app.goo.gl/ir4MVYXl5Thf98Or1
Next it will ask you if you want to enable Siri, this is up to you check it or uncheck it and click Continue like so:
https://photos.app.goo.gl/XnrCGlp89n9DGPCt1
Next it will ask you to setup your User Account, fill out all the fields and click continue.
Once the OS loads to the desktop you want to go to Finder from the menu and click on Finder Preferences. Once Preferences loads check the Show Hard Drives box and you'll see your hard drives appear on the right of the screen.
https://photos.app.goo.gl/YC8iMZWmcxTZBPrj1
https://photos.app.goo.gl/LA3ayTRL1mRGMJlo2
Now you want to install clover in UEFI mode
Once Clover is installed you want to copy the Clover folder from Clover Files to EFI, like so:
Once that is done reboot, remove the USB Installer and you should be presented with a Clover Menu. Select Boot macOS from macOS. Once your in you can change the text interface of clover by doing this:
Mount the USB drive and from the root of the Enoch files folder launch the enoch installer.
Choose Customize
If you have an EFI partition, choose install into the ESP.
If you don't have and EFI partition, choose install into the chosen path.
Check the following options.
Once checked click on install to install Enoch.
Once the install is finished copy the Extra folder from the Enoch Files folder over your existing Extra folder to transfer settings. If you have an NVIDIA card and are using web drivers you need to edit the org.chameleon.boot.plist and add NVIDIAWebDrv=Yes to the Kernel flags section.
Post Install Help
Make a forum post in the proper section with your hardware specs and what problems you are having. If its a kext issue for a piece of hardware we need the manufacturer and the make and model of the hardware to find something for you.
Apoken, pjhartin, vitorlage and 9 others liked this
by: pjhartin
#29772
Excellent guide. Works perfectly.
Egress liked this
by: Norton287
#30065
Should work I've put the NVMe patches in the config.plists
You might want to enable trim with this command from terminal:
 sudo trimforce enable
Apoken, Egress liked this
by: Norton287
#30072
Yeah
Apoken liked this
by: Norton287
#30076
Ok
Apoken liked this
by: Norton287
#30081
I look around for it.
it's in /usr/sbin I believe, not on a mac to load the disk image to look. One thing to do during install it to do a kextstat from terminal and see if IONVMeFamily.kext is loaded. If it's loaded then the kext edits have been applied to it.
Apoken liked this
  • 1
  • 2
  • 3
  • 4
  • 5
  • 20
Make sure that the cpu clock frequency is correctl[…]
Hi, i have a problem, when trying to install Sierr[…]
RADEON HD 5450 GRAPHICS ISSUES
:wtf: I've recently installed Mac OS High Sierra […]
@AlGrey , Done! Actually attached are two IOREG […]
AMD OS X Advertisements
