by: Norton287
#33240
you want to follow this tutorial: viewtopic.php?f=24&t=3039
by: shx
#35644
Ivan77 wrote:
Tue Oct 17, 2017 4:29 pm
Can someone help?
Instead of "OS X Base System" write:
OS\ X\ Base\ System
by: emanmor
#37594
im getting "no such file or directory" when trying to do the post.sh. I boot back into windows and check the USB with transmac and there is no post.sh. I downloaded from the mega link here
by: Norton287
#37604
emanmor wrote:im getting "no such file or directory" when trying to do the post.sh. I boot back into windows and check the USB with transmac and there is no post.sh. I downloaded from the mega link here
At the bottom of the first post is the USBRoot.zip that you need to extract and copy to the USB Installer.
by: dausandj
#37684
Coldang wrote:
Thu Jan 11, 2018 11:42 pm
el capitan need SSE4.1 ? im very confused.. please someone responde.
Nah, El Capitan works with SSE4a too,
Norton287 wrote:
Mon Feb 12, 2018 1:20 pm
Hi i got this problem aftaer booting from usb, after instaling post.sh without error
Waiting on <dict ID=“0”><key>IOProviderclass</key> and so on
Procie
Amd phenom 2 x4 xiforgot
My cpu support SSE4a
Thanks
by: emanmor
#37700
Alright, I got it installed and post install. What should I do next. I did Clover EFI, but what about smbios, kexts etc...
by: Norton287
#37717
View the Configuring clover video in tutorials for setting up the SMBIOS. Post.sh should have copied the kexts to your S/L/E folder for you on post install.
by: dausandj
#37791
Norton287 wrote:
Wed Feb 14, 2018 3:24 pm
yes, now i can boot to hackintosh, but my flash drive not detected on hackintosh, my keyboard and mouse working, they are usb keyboard and mouse. whats worng?
by: Norton287
#37792
You need to install the USB fixes that Shaneee made for El Capitan, you can find them here: viewtopic.php?f=23&t=2073
Follow the posts instructions and see if that fixes your USB.
For some reason, when extracting the archives of t[…]
Update to 10.13.6 so you can use the updated kerne[…]
Hello after formatting the hard drive I only have […]
There is no timing problems on AMD macos. CPU wi[…]
AMD OS X Advertisements
