• How to Install NidiaWeb drivers Sierra
  • Tutorials for the installation and post install.
Please Donate or visit my Amazon Wishlist if you've found the website useful. Thanks.
#20533 by vitorlage
Sun May 28, 2017 6:30 pm
Installing Nvidia drivers is an easy process, has for ENOCH or CLOVER
Navigate to your HDD/Extra/ folder, inside you’ll see org.chameleon.Boot.plist
Drag and drop it in your Desktop to edit it.
Now open it with Text Edit, you’re going to see this:
<key>Kernel Flags</key>
<string>-v npci=0x2000 nv_disable=1</string>
Now delete nv_disable=1 and write NVIDIAWebDrv=Yes
(Don’t forget to leave a space between arguments)
<string>-v npci=0x2000 NVIDIAWebDrv=Yes</string>
Now Save, drag and drop into its original place (HDD/Extra), when asked, click Replace.
Now download Nvidia Web drivers for your Sierra version from here: Nvidia Drivers
If you haven’t yet download Clover Configurator Vibrant edition, do it now.
Then open Clover Configurator and Mount EFI partition
Now goto System Parameters and check NvidiaWeb
Save
Hope this helps
Shaneee, Sundhar88, danielpk liked this
This topic has 3 replies
