by: soulsircus
#17099
need help ...
Succes installing Mountain Lion 10.8.5 on AMD Phenom II X4
just GPU not work
any solution to make it work?
this my ss :thumbup: :thumbup:
thx
#17134
What 6 series GPU is it?
by: soulsircus
#17183
this is my 6 series GPU
Manufacturer: Sapphire
Model: HD 6570
Device Id: 1002 6759 Mr. Shaneee thx before
#17190
Try to boot with GraphicsEnabler=No AtiConfig=Duckweed
by: soulsircus
#17277
not work mr shanee graphics still 3 mb, another solution?
#17284
Can you check inside S/L/E for AMDRadeonAccelerator.kext If it's there upload it please.
by: soulsircus
#17298
ok this the kext
https://drive.google.com/open?id=0B0N_xLl_9YtHQ25nTVZsbGhZZWc
Last edited by Shaneee on Fri Mar 31, 2017 6:59 pm, edited 1 time in total. Reason: Link coded.
#17313
The the device ID is present in all the required kexts. Apparently this card should work with just GraphicsEnabler=No although I've seen some messages about having to install with the AMD kexts removed from the installer so it'll work. Once installed the it should work but I can't see the theory behind that.
by: soulsircus
#17334
How about Enoch bootloader? Its make kext Gpu wont load or load?
#17347
Is it Clover you are using just now? If so upload the config.plist
Hi mates, In first place I want thankful to everyb[…]
10.14.1 Can't sign in App Store
this work for me https://discussions.apple.com/t[…]
Hi guys. I'm new here and new in this hackintoshin[…]
Help make USB Installer
Yes, ViciBox v.6 and later 6/7/8 can be successful[…]
