• Need help to make front panel audio work
  • Help with AMD OS X after installation.
 #36365  by pink101
 Tue Jan 09, 2018 9:29 pm
OSX 10.10.5 using VoodoHDA kext on my AMD phenom IIx4 only activate back panel audio, while the front panel still no sound. I still confused how to edit Info.plist in voodoohda.kext... here's output from getdump utility:
Found a device of class VoodooHDADevice: IOService:/AppleACPIPlatformExpert/[email protected]/AppleACPIPCI/[email protected]/IOPP/pci10de,[email protected],1/VoodooHDADevice
Probing codec #0...
 HDA Codec #0: NVidia (Unknown)
 HDA Codec ID: 0x10de0051
       Vendor: 0x10de
       Device: 0x0051
     Revision: 0x01
     Stepping: 0x00
PCI Subvendor: 0x326b174b
	startNode=1 endNode=2
	Found audio FG nid=1 startNode=4 endNode=12 total=8
Processing audio FG cad=0 nid=1...
Powering up...
Parsing audio FG...
GPIO: 0x00000000 NumGPIO=0 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=0
 nid  4 0x185600f0 as 15 seq  0 Digital-out   Jack  Digital Special Internal Unknown misc 0
 nid  5 0x185600f0 as 15 seq  0 Digital-out   Jack  Digital Special Internal Unknown misc 0
 nid  6 0x585600f0 as 15 seq  0 Digital-out   None  Digital Special Internal Unknown misc 0
 nid  7 0x585600f0 as 15 seq  0 Digital-out   None  Digital Special Internal Unknown misc 0
Parsing vendor patch...
Nodes patching. Codec = 0
NumNodes = 2
VHDevice NID= 4 Config=185600f0 (pin: Digital-o) Cap=09000094 Ctrl=00000000 -- Conns: 0=8 1=9 2=10 3=11
VHDevice NID= 5 Config=185600f0 (pin: Digital-o) Cap=09000094 Ctrl=00000000 -- Conns: 0=8 1=9 2=10 3=11
VHDevice NID= 6 Config=585600f0 (pin: Digital-o) Cap=09000094 Ctrl=00000000 -- Conns: 0=8 1=9 2=10 3=11
VHDevice NID= 7 Config=585600f0 (pin: Digital-o) Cap=09000094 Ctrl=00000000 -- Conns: 0=8 1=9 2=10 3=11
VHDevice NID= 8 Config=00000000 (audio output  ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID= 9 Config=00000000 (audio output  ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=10 Config=00000000 (audio output  ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=11 Config=00000000 (audio output  ) Cap=00000000 Ctrl=00000000 -- Conns:
Disabling nonaudio...
Disabling useless...
Patched pins configuration:
 nid  6 0x585600f0 as 15 seq  0 Digital-out   None  Digital Special Internal Unknown misc 0 [DISABLED]
 nid  7 0x585600f0 as 15 seq  0 Digital-out   None  Digital Special Internal Unknown misc 0 [DISABLED]
Parsing pin associations...
2 associations found:
Association 0 (15) out:
 Pin nid=4 seq=0
   Redir type=-1 jack=0 def=-1
Association 1 (15) out:
 Pin nid=5 seq=0
Building AFG tree...
Tracing association 0 (15)
 Tracing pin 4 with min nid 0
   nid 8 returned 8
   nid 9 returned 9
   nid 10 returned 10
   nid 11 returned 11
  nid 4 returned 8
 Pin 4 traced to DAC 8
Association 0 (15) trace succeeded
Tracing association 1 (15)
 Tracing pin 5 with min nid 0
   nid 8 busy by association 0
   nid 9 returned 9
   nid 10 returned 10
   nid 11 returned 11
  nid 5 returned 9
 Pin 5 traced to DAC 9
Association 1 (15) trace succeeded
Tracing input monitor
Tracing other input monitors
Tracing beeper
Disabling unassociated widgets...
Disabling nonselected inputs...
Disabling crossassociated connections...
Binding associations to channels...
Assigning names to signal sources...
Parsing Ctls...
Assigning mixers to the tree...
Preparing pin controls...
AFG commit...
Creating PCM devices...
pcmAttach: HDA NVidia (Unknown) PCM #0 DisplayPort at cad 0 nid 1
| DUMPING PCM Playback/Record Channels |
Playback:
     Stream cap: 0x00000005
                 AC3 PCM
        PCM cap: 0x000e07f0
                 16 20 24 bits, 32 44 48 88 96 176 192 KHz
            DAC: 8
| DUMPING Playback/Record Paths |
Playback:
    nid=4 [pin: Digital-out (HDMI)]
      + <- nid=8 [audio output] [src: pcm] bindSeq=00000001
| DUMPING Volume Controls |
OSS mixer initialization...
Registering PCM channels...
pcmAttach: HDA NVidia (Unknown) PCM #1 DisplayPort at cad 0 nid 1
Playback:
                 AC3 PCM
        PCM cap: 0x000e07f0
            DAC: 9
Playback:
    nid=5 [pin: Digital-out (HDMI)]
      + <- nid=9 [audio output] [src: pcm] bindSeq=00000001
FG config/quirks: forcestereo ivref50 ivref80 ivref100 ivref
HP switch init...
| DUMPING HDA NODES |
Default Parameter
         IN amp: 0x00000000
        OUT amp: 0x00000000
            nid: 4
           Name: pin: Digital-out (HDMI)
     Widget cap: 0x00407381
                 DIGITAL UNSOL 8CH
    Association: 0 (0x00000001)
        Pin cap: 0x09000094
                 PDC OUT HDMI DP HBR
     Pin config: 0x185600f0
    Pin control: 0x00000040 OUT
    connections: 4 enabled 1
          + <- nid=8 [audio output] (selected)
          + [DISABLED] <- nid=9 [audio output]
          + [DISABLED] <- nid=10 [audio output] [DISABLED]
          + [DISABLED] <- nid=11 [audio output] [DISABLED]
            nid: 5
                 DIGITAL UNSOL 8CH
    Association: 1 (0x00000001)
        Pin cap: 0x09000094
                 PDC OUT HDMI DP HBR
          + [DISABLED] <- nid=8 [audio output]
          + <- nid=9 [audio output] (selected)
            nid: 6 [DISABLED]
                 DIGITAL UNSOL 8CH
        Pin cap: 0x09000094
                 PDC OUT HDMI DP HBR
     Pin config: 0x585600f0
    Pin control: 0x00000000
    connections: 4 enabled 4
          + <- nid=10 [audio output] [DISABLED]
          + <- nid=11 [audio output] [DISABLED]
            nid: 7 [DISABLED]
                 DIGITAL UNSOL 8CH
        Pin cap: 0x09000094
                 PDC OUT HDMI DP HBR
            nid: 8
     Widget cap: 0x000062b1
                 DIGITAL UNSOL STRIPE 8CH
            OSS: pcm (pcm)
                 AC3 PCM
        PCM cap: 0x000e07f0
            nid: 9
            OSS: pcm (pcm)
                 AC3 PCM
        PCM cap: 0x000e07f0
            nid: 10 [DISABLED]
                 AC3 PCM
        PCM cap: 0x000e07f0
            nid: 11 [DISABLED]
                 AC3 PCM
        PCM cap: 0x000e07f0
Found a device of class VoodooHDADevice: IOService:/AppleACPIPlatformExpert/[email protected]/AppleACPIPCI/[email protected],2/VoodooHDADevice
Probing codec #2...
 HDA Codec #2: Realtek ALC662
 HDA Codec ID: 0x10ec0662
       Vendor: 0x10ec
       Device: 0x0662
     Revision: 0x01
     Stepping: 0x01
PCI Subvendor: 0x821f1565
	Found audio FG nid=1 startNode=2 endNode=39 total=37
Processing audio FG cad=2 nid=1...
Powering up...
Parsing audio FG...
GPIO: 0x40000002 NumGPIO=2 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=1
 nid 20 0x01014410 as  1 seq  0 Line-out      Jack  1/8     Rear    External Green   misc 2
 nid 21 0x411111f0 as 15 seq  0 Speaker       None  1/8     Rear    External Black   misc 0 NoPresenceDetect
 nid 22 0x411111f0 as 15 seq  0 Speaker       None  1/8     Rear    External Black   misc 0 NoPresenceDetect
 nid 24 0x01a19c30 as  3 seq  0 Microphone    Jack  1/8     Rear    External Pink    misc 6
 nid 25 0x02a19c31 as  3 seq  1 Microphone    Jack  1/8     Front   External Pink    misc 6
 nid 26 0x0181343f as  3 seq 15 Line-in       Jack  1/8     Rear    External Blue    misc 2
 nid 27 0x02214c1f as  1 seq 15 Headphones    Jack  1/8     Front   External Green   misc 6
 nid 28 0x411111f0 as 15 seq  0 Speaker       None  1/8     Rear    External Black   misc 0 NoPresenceDetect
Patching widget caps nid=29 0x00400000 -> 0x00700000
 nid 30 0x01441120 as  2 seq  0 SPDIF-out     Jack  RCA     Rear    External Black   misc 0 NoPresenceDetect
Nodes patching. Codec = 2
NumNodes = 2
VHDevice NID= 2 Config=00000000 (audio output  ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID= 3 Config=00000000 (audio output  ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID= 4 Config=00000000 (audio output  ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID= 5 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID= 6 Config=00000000 (audio output  ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID= 7 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID= 8 Config=00000000 (audio input   ) Cap=00000000 Ctrl=00000000 -- Conns: 0=35
VHDevice NID= 9 Config=00000000 (audio input   ) Cap=00000000 Ctrl=00000000 -- Conns: 0=34
VHDevice NID=10 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=12 Config=00000000 (audio mixer   ) Cap=00000000 Ctrl=00000000 -- Conns: 0=2 1=11
VHDevice NID=13 Config=00000000 (audio mixer   ) Cap=00000000 Ctrl=00000000 -- Conns: 0=3 1=11
VHDevice NID=14 Config=00000000 (audio mixer   ) Cap=00000000 Ctrl=00000000 -- Conns: 0=4 1=11
VHDevice NID=15 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=16 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=17 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=18 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=19 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=20 Config=01014410 (pin: Line-out ) Cap=0001003c Ctrl=00000020 -- Conns: 0=12
VHDevice NID=21 Config=411111f0 (pin: Speaker () Cap=00010034 Ctrl=00000020 -- Conns: 0=13
VHDevice NID=22 Config=411111f0 (pin: Speaker () Cap=00000034 Ctrl=00000020 -- Conns: 0=14
VHDevice NID=23 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=24 Config=01a19c30 (pin: Microphon) Cap=00001734 Ctrl=00000020 -- Conns: 0=14
VHDevice NID=25 Config=02a19c31 (pin: Microphon) Cap=0000173c Ctrl=00000020 -- Conns: 0=12 1=14
VHDevice NID=26 Config=0181343f (pin: Line-in () Cap=00000034 Ctrl=00000020 -- Conns: 0=13
VHDevice NID=27 Config=02214c1f (pin: Headphone) Cap=0000173c Ctrl=00000020 -- Conns: 0=12 1=14
VHDevice NID=28 Config=411111f0 (pin: Speaker () Cap=00000020 Ctrl=00000020 -- Conns:
VHDevice NID=29 Config=00000000 (beep widget   ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=30 Config=01441120 (pin: SPDIF-out) Cap=00000010 Ctrl=00000040 -- Conns: 0=6
VHDevice NID=31 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=32 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=33 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=34 Config=00000000 (audio mixer   ) Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=28 5=29 6=20 7=21 8=22 9=11
VHDevice NID=35 Config=00000000 (audio mixer   ) Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=28 5=29 6=20 7=21 8=22 9=11
VHDevice NID=36 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=37 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=38 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns:
 Disabling nid 12 connection 1 due to disabled child widget.
 Disabling nid 13 connection 1 due to disabled child widget.
 Disabling nid 14 connection 1 due to disabled child widget.
 Disabling nid 34 connection 4 due to disabled child widget.
 Disabling nid 34 connection 7 due to disabled child widget.
 Disabling nid 34 connection 8 due to disabled child widget.
 Disabling nid 34 connection 9 due to disabled child widget.
 Disabling nid 35 connection 4 due to disabled child widget.
 Disabling nid 35 connection 7 due to disabled child widget.
 Disabling nid 35 connection 8 due to disabled child widget.
 Disabling nid 35 connection 9 due to disabled child widget.
 nid 21 0x411111f0 as 15 seq  0 Speaker       None  1/8     Rear    External Black   misc 0 NoPresenceDetect [DISABLED]
 nid 22 0x411111f0 as 15 seq  0 Speaker       None  1/8     Rear    External Black   misc 0 NoPresenceDetect [DISABLED]
 nid 28 0x411111f0 as 15 seq  0 Speaker       None  1/8     Rear    External Black   misc 0 NoPresenceDetect [DISABLED]
3 associations found:
Association 0 (1) out:
 Pin nid=20 seq=0
 Pin nid=27 seq=15
   Redir type=0 jack=15 def=0
Association 1 (2) out:
 Pin nid=30 seq=0
   Redir type=-1 jack=-1 def=0
Association 2 (3) in:
 Pin nid=24 seq=0
 Pin nid=25 seq=1
 Pin nid=26 seq=15
Tracing association 0 (1)
 Tracing pin 20 with min nid 0
    nid 2 returned 2
   nid 12 returned 2
  nid 20 returned 2
 Pin 20 traced to DAC 2
 Tracing pin 27 with min nid 0 and hpredir 0
    nid 2 returned 2
   nid 12 returned 2
  nid 27 returned 2
 Pin 27 traced to DAC 2 and hpredir 0
Association 0 (1) trace succeeded
Tracing association 1 (2)
 Tracing pin 30 with min nid 0
   nid 6 returned 6
  nid 30 returned 6
 Pin 30 traced to DAC 6
Association 1 (2) trace succeeded
Tracing association 2 (3)
 Tracing pin 24 to ADC 8
  tracing via nid 24
   tracing via nid 34
    tracing via nid 9
    nid 9 returned 0
   nid 34 returned 0
   tracing via nid 35
    tracing via nid 8
    nid 8 returned 1
   nid 35 returned 1
  nid 24 returned 1
 Pin 24 traced to ADC 8
 Tracing pin 25 to ADC 8
  tracing via nid 25
   tracing via nid 34
    tracing via nid 9
    nid 9 returned 0
   nid 34 returned 0
   tracing via nid 35
    tracing via nid 8
    nid 8 returned 1
   nid 35 returned 1
  nid 25 returned 1
 Pin 25 traced to ADC 8
 Tracing pin 26 to ADC 8
  tracing via nid 26
   tracing via nid 34
    tracing via nid 9
    nid 9 returned 0
   nid 34 returned 0
   tracing via nid 35
    tracing via nid 8
    nid 8 returned 1
   nid 35 returned 1
  nid 26 returned 1
 Pin 26 traced to ADC 8
Association 2 (3) trace succeeded
 Tracing nid mix 35 to out
  tracing via nid 35
   tracing via nid 8
   nid 8 busy by input association 2
  nid 35 returned 0
 Tracing nid complex 24 to out
  tracing via nid 24
   tracing via nid 34
    tracing via nid 9
    nid 9 returned 0
   nid 34 returned 0
   tracing via nid 35
   nid 35 busy by input association 2
  nid 24 returned 0
 Tracing nid complex 25 to out
  tracing via nid 25
   tracing via nid 34
    tracing via nid 9
    nid 9 returned 0
   nid 34 returned 0
   tracing via nid 35
  nid 25 returned 0
 Tracing nid complex 26 to out
  tracing via nid 26
   tracing via nid 34
    tracing via nid 9
    nid 9 returned 0
   nid 34 returned 0
   tracing via nid 35
  nid 26 returned 0
Tracing beeper
 Tracing nid 29 to out
  tracing via nid 29
   tracing via nid 34
    tracing via nid 9
    nid 9 returned 0
   nid 34 returned 0
   tracing via nid 35
  nid 29 returned 0
Parsing Ctls...
Ctl overflow!
AFG commit...
pcmAttach: HDA Realtek ALC662 PCM #0 Analog at cad 2 nid 1
Playback:
     Stream cap: 0x00000001
                 PCM
        PCM cap: 0x000e0160
                 16 20 24 bits, 44 48 96 KHz
            DAC: 2
Record:
                 PCM
        PCM cap: 0x00060160
                 16 20 bits, 44 48 96 KHz
            ADC: 8
Playback:
    nid=20 [pin: Line-out (Green Rear)]
      + <- nid=12 [audio mixer] [src: mix] bindSeq=00008001
             + <- nid=2 [audio output] [src: pcm] bindSeq=00008001
    nid=27 [pin: Headphones (Green Front)]
Record:
    nid=8 [audio input]
      + <- nid=35 [audio mixer] [src: mix] bindSeq=00008003
             + <- nid=24 [pin: Microphone (Pink Rear)] [src: mic] bindSeq=00000001
             + <- nid=25 [pin: Microphone (Pink Front)] [src: monitor] bindSeq=00000002
             + <- nid=26 [pin: Line-in (Blue Rear)] [src: line] bindSeq=00008000
             + <- nid=29 [beep widget]
Input Mix:
Master Volume (OSS: vol)
   +- control  1 (nid   2 out):    dir - out oss: vol, pcm, mix -64/+0dB (65 steps)
   +- control  3 (nid  12 in   0): dir - out oss: vol, pcm, mix mute
   +- control  4 (nid  20 out):    dir - out oss: vol, mix mute
   +- control 10 (nid  27 out):    dir - out oss: vol, mix mute
PCM Volume (OSS: pcm)
Microphone Volume (OSS: mic)
   +- control  6 (nid  24 in   0): dir - in oss: mic +0/+30dB (4 steps)
   +- control 12 (nid  35 in   0): dir - in oss: mic, rec mute
Microphone2 Volume (OSS: monitor)
   +- control  8 (nid  25 in   0): dir - in oss: monitor +0/+30dB (4 steps)
   +- control 13 (nid  35 in   1): dir - in oss: rec, monitor mute
Line-in Volume (OSS: line)
   +- control 14 (nid  35 in   2): dir - in oss: line, rec mute
Speaker/Beep Volume (OSS: speaker)
   +- control 16 (nid  35 in   5): dir - in oss: speaker, rec mute
Recording Level (OSS: rec)
   +- control  2 (nid   8 in   0): dir - in oss: mix, rec -13/+33dB (32 steps) + mute
Input Mix Level (OSS: mix)
pcmAttach: HDA Realtek ALC662 PCM #1 Digital at cad 2 nid 1
Playback:
                 AC3 PCM
        PCM cap: 0x001e0160
                 16 20 24 32 bits, 44 48 96 KHz
            DAC: 6
Playback:
    nid=30 [pin: SPDIF-out (Black Rear)]
      + <- nid=6 [audio output] [src: pcm] bindSeq=00000001
HP switch init...
| DUMPING HDA NODES |
Default Parameter
                 PCM
        PCM cap: 0x000e0160
         IN amp: 0x00000000
        OUT amp: 0x00000000
            nid: 2
     Widget cap: 0x0000001d
                 STEREO
    Association: 0 (0x00008001)
            OSS: pcm (pcm)
                 PCM
        PCM cap: 0x000e0160
     Output amp: 0x00034040
                 mute=0 step=64 size=3 offset=64
     Output val: [0x29 0x29]
            nid: 3 [DISABLED]
                 STEREO
                 PCM
        PCM cap: 0x000e0160
     Output val: [0x40 0x40]
            nid: 4 [DISABLED]
                 STEREO
                 PCM
        PCM cap: 0x000e0160
            nid: 5 [DISABLED]
     Widget cap: 0x00f00000
            nid: 6
     Widget cap: 0x00000211
                 DIGITAL STEREO
            OSS: pcm (pcm)
                 PCM
        PCM cap: 0x001e0160
            nid: 7 [DISABLED]
            nid: 8
     Widget cap: 0x0010011b
                 STEREO
    Association: 2 (0x00008003)
                 PCM
        PCM cap: 0x00060160
      Input amp: 0x80051f09
                 mute=1 step=31 size=5 offset=9
      Input val: [0x19 0x19]
    connections: 1 enabled 1
            nid: 9 [DISABLED]
                 STEREO
                 PCM
        PCM cap: 0x00060160
      Input val: [0x89 0x89]
          + <- nid=34 [audio mixer] [DISABLED]
            nid: 10 [DISABLED]
            nid: 11 [DISABLED]
     Widget cap: 0x0020010b
                 STEREO
      Input amp: 0x80051f17
                 mute=1 step=31 size=5 offset=23
      Input val: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
    connections: 9 enabled 9
          + <- nid=27 [pin: Headphones (Green Front)]
          + <- nid=28 [pin: Speaker (None)] [DISABLED]
          + <- nid=20 [pin: Line-out (Green Rear)]
          + <- nid=21 [pin: Speaker (None)] [DISABLED]
          + <- nid=22 [pin: Speaker (None)] [DISABLED]
            nid: 12
                 STEREO
            OSS: mix (mix)
      Input amp: 0x80000000
                 mute=1 step=0 size=0 offset=0
      Input val: [0x00 0x00] [0x80 0x80]
    connections: 2 enabled 1
          + [DISABLED] <- nid=11 [audio mixer] [DISABLED]
            nid: 13 [DISABLED]
                 STEREO
          + <- nid=3 [audio output] [DISABLED]
            nid: 14 [DISABLED]
                 STEREO
          + <- nid=4 [audio output] [DISABLED]
            nid: 15 [DISABLED]
            nid: 16 [DISABLED]
            nid: 17 [DISABLED]
            nid: 18 [DISABLED]
            nid: 19 [DISABLED]
            nid: 20
           Name: pin: Line-out (Green Rear)
     Widget cap: 0x0040018d
                 UNSOL STEREO
        Pin cap: 0x0001003c
                 PDC HP OUT IN EAPD
     Pin config: 0x01014410
           EAPD: 0x00000002
     Output amp: 0x80000000
     Output val: [0x00 0x00]
            nid: 21 [DISABLED]
           Name: pin: Speaker (None)
                 UNSOL STEREO
        Pin cap: 0x00010034
                 PDC OUT IN EAPD
     Pin config: 0x411111f0
           EAPD: 0x00000002
     Output val: [0x80 0x80]
          + <- nid=13 [audio mixer] [DISABLED]
            nid: 22 [DISABLED]
                 UNSOL STEREO
        Pin cap: 0x00000034
                 PDC OUT IN
          + <- nid=14 [audio mixer] [DISABLED]
            nid: 23 [DISABLED]
            nid: 24
           Name: pin: Microphone (Pink Rear)
     Widget cap: 0x0040018f
                 UNSOL STEREO
    Association: 2 (0x00000001)
            OSS: mic (mic)
        Pin cap: 0x00001734
                 PDC OUT IN VREF[ 50 80 GROUND HIZ ]
     Pin config: 0x01a19c30
    Pin control: 0x00000024 IN VREFs
      Input amp: 0x00270300
                 mute=0 step=3 size=39 offset=0
      Input val: [0x02 0x02]
    connections: 1 enabled 0
          + [DISABLED] <- nid=14 [audio mixer] [DISABLED]
            nid: 25
           Name: pin: Microphone (Pink Front)
                 UNSOL STEREO
    Association: 2 (0x00000002)
            OSS: monitor (monitor)
        Pin cap: 0x0000173c
                 PDC HP OUT IN VREF[ 50 80 GROUND HIZ ]
     Pin config: 0x02a19c31
      Input val: [0x02 0x02] [0x00 0x00]
    connections: 2 enabled 0
          + [DISABLED] <- nid=12 [audio mixer] (selected)
            nid: 26
           Name: pin: Line-in (Blue Rear)
                 UNSOL STEREO
    Association: 2 (0x00008000)
            OSS: line (line)
        Pin cap: 0x00000034
                 PDC OUT IN
     Pin config: 0x0181343f
    Pin control: 0x00000020 IN
          + [DISABLED] <- nid=13 [audio mixer] [DISABLED]
            nid: 27
           Name: pin: Headphones (Green Front)
                 UNSOL STEREO
    Association: 0 (0x00008000)
        Pin cap: 0x0000173c
     Pin config: 0x02214c1f
    Pin control: 0x000000c0 HP OUT
      Input val: [0x00 0x00] [0x00 0x00]
          + <- nid=12 [audio mixer] (selected)
            nid: 28 [DISABLED]
     Widget cap: 0x00400001
                 STEREO
        Pin cap: 0x00000020
                 IN
            nid: 29
     Widget cap: 0x00700000
    Association: -2 (0x00000000)
            OSS: speaker (speaker)
            nid: 30
           Name: pin: SPDIF-out (Black Rear)
     Widget cap: 0x00400300
                 DIGITAL
        Pin cap: 0x00000010
                 OUT
     Pin config: 0x01441120
            nid: 31 [DISABLED]
            nid: 32 [DISABLED]
     Widget cap: 0x00f00040
                 PROC
            nid: 33 [DISABLED]
            nid: 34 [DISABLED]
                 STEREO
      Input val: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
    connections: 10 enabled 6
          + [DISABLED] <- nid=28 [pin: Speaker (None)] [DISABLED]
          + [DISABLED] <- nid=21 [pin: Speaker (None)] [DISABLED]
          + [DISABLED] <- nid=22 [pin: Speaker (None)] [DISABLED]
            nid: 35
                 STEREO
            OSS: mix (mix)
      Input val: [0x00 0x00] [0x00 0x00] [0x00 0x00] [0x00 0x00] [0x80 0x80] [0x00 0x00] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80]
    connections: 10 enabled 4
          + [DISABLED] <- nid=27 [pin: Headphones (Green Front)]
          + [DISABLED] <- nid=20 [pin: Line-out (Green Rear)]
            nid: 36 [DISABLED]
            nid: 37 [DISABLED]
            nid: 38 [DISABLED]
On linux, both front and back audio work just fine, but i don't know why on OSX the front panel seems to be disabled.
