by: pink101
#33023
A year ago i posted here about my problem when running Yosemite installer. Now i have some nvidia graphic card to give hackintosh another try. The installer run without a problem, but i run into some problem after the installation... It seems the system hang right before or on some kernels after 'Waiting for DSMOS...' i've read in forum posts that it was a FakeSMC problem, but in the screenshot we can see that the FakeSMC is actually already running, so the problem probably was not FakeSMC. Can anyone help me here?
i've tried several xnu 14.0.0 kernels that was on insanelymac and all of them stop around that line, some kernel stop at waiting for DSMOS, and the kernel from this forum stop like in the picture but then give opemu error: high reg ssse
i also tried several FakeSMC files, and this is the farthest i can go before the system hangs... some FakeSMC even give a kernel panic and corecrypto kext problem...
here's my system taken from linux lshw:
freaks
    description: Desktop Computer
    product: A880G+ (To Be Filled By O.E.M.)
    vendor: BIOSTAR Group
    serial: None
    width: 64 bits
    capabilities: smbios-2.6 dmi-2.6 vsyscall32
    configuration: boot=normal chassis=desktop family=To Be Filled By O.E.M. sku=To Be Filled By O.E.M. uuid=00020003-0004-0005-0006-000700080009
  *-core
       description: Motherboard
       product: A880G+
       physical id: 0
       serial: None
       slot: To Be Filled By O.E.M.
     *-firmware
          description: BIOS
          vendor: American Megatrends Inc.
          physical id: 0
          version: 080016
          date: 01/25/2011
          capacity: 960KiB
          capabilities: isa pci pnp apm upgrade shadowing escd cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb ls120boot zipboot biosbootspecification
     *-cpu
          description: CPU
          product: AMD Phenom(tm) II X4 945 Processor
          vendor: Advanced Micro Devices [AMD]
          physical id: 4
          bus info: [email protected]
          version: AMD Phenom(tm) II X4 945 Processor
          serial: To Be Filled By O.E.M.
          slot: CPU 1
          capacity: 3GHz
          width: 64 bits
          clock: 200MHz
          capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp 3dnowext 3dnow constant_tsc rep_good nopl nonstop_tsc extd_apicid pni monitor cx16 popcnt lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt hw_pstate npt lbrv svm_lock nrip_save cpufreq
          configuration: cores=4 enabledcores=4
        *-cache:0
             description: L1 cache
             physical id: 5
             slot: L1-Cache
             capacity: 512KiB
             capabilities: pipeline-burst internal varies
        *-cache:1
             description: L2 cache
             physical id: 6
             slot: L2-Cache
             capacity: 2MiB
        *-cache:2
             description: L3 cache
             physical id: 7
             slot: L3-Cache
             capacity: 6MiB
     *-memory
          description: System Memory
          physical id: 28
          slot: System board or motherboard
        *-bank:0
             description: DIMM Synchronous 667 MHz (1.5 ns)
             product: CMZ8GX3M2A1600C9
             vendor: Corsair
             physical id: 0
             serial: 00000000
             slot: DIMM0
             width: 64 bits
             clock: 667MHz (1.5ns)
        *-bank:1
             vendor: Corsair
             physical id: 1
             serial: 00000000
             slot: DIMM1
             width: 64 bits
        *-bank:2
             description: [empty]
             product: ModulePartNumber02
             vendor: Manufacturer02
             physical id: 2
             serial: SerNum02
             slot: DIMM2
        *-bank:3
             product: ModulePartNumber03
             vendor: Manufacturer03
             physical id: 3
             serial: SerNum03
             slot: DIMM3
     *-pci:0
          description: Host bridge
          product: RS880 Host Bridge
          physical id: 100
          bus info: [email protected]:00:00.0
          version: 00
          width: 32 bits
          clock: 66MHz
        *-pci:0
             description: PCI bridge
             product: RS780 PCI to PCI bridge (ext gfx port 0)
             physical id: 2
             bus info: [email protected]:00:02.0
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: pci pm pciexpress msi ht normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:40 ioport:d000(size=4096) memory:fcf00000-fdffffff ioport:d6000000(size=167772160)
           *-display
                description: VGA compatible controller
                product: NVIDIA Corporation
                vendor: NVIDIA Corporation
                physical id: 0
                bus info: [email protected]:01:00.0
                version: a1
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
                configuration: driver=nvidia latency=0
                resources: irq:43 memory:fd000000-fdffffff memory:d8000000-dfffffff memory:d6000000-d7ffffff ioport:d800(size=128) memory:fcf80000-fcffffff
           *-multimedia
                description: Audio device
                physical id: 0.1
                bus info: [email protected]:01:00.1
                version: a1
                width: 32 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list
                configuration: driver=snd_hda_intel latency=0
                resources: irq:19 memory:fcf7c000-fcf7ffff
        *-pci:1
             product: RS780 PCI to PCI bridge (PCIE port 3)
             physical id: 7
             bus info: [email protected]:00:07.0
             version: 00
             width: 32 bits
             clock: 33MHz
             resources: irq:41 ioport:e000(size=4096) memory:fea00000-feafffff ioport:fbf00000(size=1048576)
           *-network DISABLED
                description: Ethernet interface
                product: RTL8111/8168B PCI Express Gigabit Ethernet controller
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: [email protected]:02:00.0
                logical name: eth0
                version: 03
                serial: 00:30:67:e5:ec:99
                capacity: 1Gbit/s
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=N/A latency=0 link=no multicast=yes port=MII speed=10Mbit/s
                resources: irq:42 ioport:e800(size=256) memory:fbffb000-fbffbfff memory:fbffc000-fbffffff memory:feae0000-feafffff
        *-storage
             description: SATA controller
             product: SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode]
             vendor: Advanced Micro Devices [AMD] nee ATI
             physical id: 11
             bus info: [email protected]:00:11.0
             logical name: scsi0
             version: 00
             width: 32 bits
             clock: 66MHz
             capabilities: storage pm ahci_1.0 bus_master cap_list emulated
             configuration: driver=ahci latency=64
             resources: irq:22 ioport:c000(size=8) ioport:b000(size=4) ioport:a000(size=8) ioport:9000(size=4) ioport:8000(size=16) memory:fe9ffc00-fe9fffff
           *-disk
                description: ATA Disk
                product: WDC WD5000AAKX-0
                vendor: Western Digital
                physical id: 0.0.0
                bus info: [email protected]:0.0.0
                logical name: /dev/sda
                version: 15.0
                serial: WD-WCAYUY560704
                capabilities: partitioned partitioned:dos
                configuration: ansiversion=5 sectorsize=512 signature=cd50cd50
              *-volume:0
                   description: EXT4 volume
                   vendor: Linux
                   physical id: 1
                   bus info: [email protected]:0.0.0,1
                   logical name: /dev/sda1
                   logical name: /
                   version: 1.0
                   serial: dc2ce711-cc5a-40f4-a5e2-6978c0afdbe8
                   capacity: 82GiB
                   capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink extents ext4 ext2 initialized
                   configuration: created=2012-03-01 17:28:49 filesystem=ext4 label=LinuxOS lastmountpoint=/ modified=2017-11-24 14:10:51 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro,user_xattr,acl,barrier=1,data=ordered mounted=2017-11-24 14:10:51 state=mounted
              *-volume:1
                   description: Extended partition
                   physical id: 2
                   bus info: [email protected]:0.0.0,2
                   logical name: /dev/sda2
                   capacity: 382GiB
                   capabilities: primary extended partitioned partitioned:extended
                 *-logicalvolume:0
                      description: Linux filesystem partition
                      physical id: 5
                      logical name: /dev/sda5
                      logical name: /media/Data1
                      capacity: 195GiB
                      configuration: mount.fstype=ext4 mount.options=rw,nosuid,nodev,relatime,user_xattr,acl,barrier=1,data=ordered state=mounted
                 *-logicalvolume:1
                      physical id: 6
                      logical name: /dev/sda6
                      logical name: /media/Data2
                      capacity: 172GiB
                 *-logicalvolume:2
                      description: Linux swap / Solaris partition
                      physical id: 7
                      logical name: /dev/sda7
                      capacity: 14GiB
                      capabilities: nofs
        *-usb:0
             description: USB controller
             product: SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
             physical id: 12
             bus info: [email protected]:00:12.0
             version: 00
             width: 32 bits
             clock: 66MHz
             capabilities: ohci bus_master
             configuration: driver=ohci_hcd latency=64
             resources: irq:16 memory:fe9fe000-fe9fefff
        *-usb:1
             product: SB7x0 USB OHCI1 Controller
             physical id: 12.1
             bus info: [email protected]:00:12.1
             version: 00
             width: 32 bits
             clock: 66MHz
             resources: irq:16 memory:fe9fd000-fe9fdfff
        *-usb:2
             product: SB7x0/SB8x0/SB9x0 USB EHCI Controller
             physical id: 12.2
             bus info: [email protected]:00:12.2
             version: 00
             width: 32 bits
             clock: 66MHz
             capabilities: pm debug ehci bus_master cap_list
             configuration: driver=ehci_hcd latency=64
             resources: irq:17 memory:fe9ff800-fe9ff8ff
        *-usb:3
             physical id: 13
             bus info: [email protected]:00:13.0
             version: 00
             width: 32 bits
             clock: 66MHz
             resources: irq:18 memory:fe9fc000-fe9fcfff
        *-usb:4
             physical id: 13.1
             bus info: [email protected]:00:13.1
             version: 00
             width: 32 bits
             clock: 66MHz
             resources: irq:18 memory:fe9fb000-fe9fbfff
        *-usb:5
             physical id: 13.2
             bus info: [email protected]:00:13.2
             version: 00
             width: 32 bits
             clock: 66MHz
             resources: irq:19 memory:fe9ff400-fe9ff4ff
        *-serial UNCLAIMED
             description: SMBus
             product: SBx00 SMBus Controller
             physical id: 14
             bus info: [email protected]:00:14.0
             version: 3c
             width: 32 bits
             clock: 66MHz
             capabilities: ht cap_list
             configuration: latency=0
        *-ide
             description: IDE interface
             product: SB7x0/SB8x0/SB9x0 IDE Controller
             physical id: 14.1
             bus info: [email protected]:00:14.1
             version: 00
             width: 32 bits
             clock: 66MHz
             capabilities: ide msi bus_master cap_list
             configuration: driver=pata_atiixp latency=64
             resources: irq:16 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:ff00(size=16)
        *-multimedia
             product: SBx00 Azalia (Intel HDA)
             physical id: 14.2
             bus info: [email protected]:00:14.2
             version: 00
             width: 64 bits
             clock: 33MHz
             capabilities: pm bus_master cap_list
             configuration: driver=snd_hda_intel latency=64
             resources: irq:16 memory:fe9f4000-fe9f7fff
        *-isa
             description: ISA bridge
             product: SB7x0/SB8x0/SB9x0 LPC host controller
             physical id: 14.3
             bus info: [email protected]:00:14.3
             version: 00
             width: 32 bits
             clock: 66MHz
             capabilities: isa bus_master
        *-pci:2
             product: SBx00 PCI to PCI Bridge
             physical id: 14.4
             bus info: [email protected]:00:14.4
             version: 00
             width: 32 bits
             clock: 66MHz
             capabilities: pci subtractive_decode bus_master
             resources: memory:feb00000-febfffff
           *-network
                description: Wireless interface
                product: AR5212/AR5213 Wireless Network Adapter
                vendor: Atheros Communications Inc.
                physical id: 5
                bus info: [email protected]:03:05.0
                logical name: wlan0
                version: 01
                serial: 00:14:78:ec:c0:1b
                width: 32 bits
                clock: 33MHz
                capabilities: pm bus_master cap_list ethernet physical wireless
                configuration: broadcast=yes driver=ath5k driverversion=3.2.0-4-amd64 firmware=N/A ip=192.168.100.100 latency=168 link=yes maxlatency=28 mingnt=10 multicast=yes wireless=IEEE 802.11bg
                resources: irq:20 memory:febf0000-febfffff
        *-usb:6
             product: SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
             physical id: 14.5
             bus info: [email protected]:00:14.5
             version: 00
             width: 32 bits
             clock: 66MHz
             resources: irq:18 memory:fe9fa000-fe9fafff
     *-pci:1
          product: Family 10h Processor HyperTransport Configuration
          physical id: 101
          bus info: [email protected]:00:18.0
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:2
          product: Family 10h Processor Address Map
          physical id: 102
          bus info: [email protected]:00:18.1
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:3
          product: Family 10h Processor DRAM Controller
          physical id: 103
          bus info: [email protected]:00:18.2
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:4
          product: Family 10h Processor Miscellaneous Control
          physical id: 104
          bus info: [email protected]:00:18.3
          version: 00
          width: 32 bits
          clock: 33MHz
          configuration: driver=k10temp
          resources: irq:0
     *-pci:5
          product: Family 10h Processor Link Control
          physical id: 105
          bus info: [email protected]:00:18.4
          version: 00
          width: 32 bits
          clock: 33MHz
  *-network DISABLED
       physical id: 1
       logical name: tap0
       serial: 86:32:10:e0:55:36
       capabilities: ethernet physical
       configuration: autonegotiation=off broadcast=yes driver=tun driverversion=1.6 duplex=full firmware=N/A link=no multicast=yes port=twisted pair speed=10Mbit/s
#33024
You need to make sure nv_disable=1 is in the org.chameleon.boot.plist for your nvidia card for installation.
#33025
Norton287 wrote:You need to make sure nv_disable=1 is in the org.chameleon.boot.plist for your nvidia card for installation.
i already try that... with -x GraphicsEnabler=No nv_disable=1 and stuck at the same line... btw it's post installation, the installer run just fine... it can pass the DSMOS waiting.
#33026
If installation was fine with the usb the postinstall should be exactly the same, try reimaging the installer USB.
#33029
Norton287 wrote:If installation was fine with the usb the postinstall should be exactly the same, try reimaging the installer USB.
i thought so too, that's why i retry it several times and still stuck at the same line. At some point i even tried delete all the kext in the system and replace it all with the one that's on the installer and it still stuck at the same line... i don't know why it's doing that..
#33030
If your doing postinstall the kext don't matter you're booting off the USB to YosemiteAMD
#33036
Is it possible that ACPI table/DSDT causing this situation?
here's ioreg output that i get from the installer.
I don't know how to edit DSDT and what does it do to osx/hackintosh system, but in many forums people tweak their DSDT and one of them related to re-naming of the PCI device that hold graphic card. In my IOreg output from the installer, it shows that my graphic card is attached to PCE2, is that somehow related to why the system hang at the current line?
#33038
for install you don't really need a dsdt just delete it from the config
#33039
Norton287 wrote:for install you don't really need a dsdt just delete it from the config
i don't have it yet on my Extra folder and my chameleon plist... i'm just guessing weather i should edit it to make my system work
#33040
You don't need a DSDT to make the installer work, what I would do is download YosemiteV2 again and reburn it to usb and try again without modifying kernels and configs.
Hey, I gived up last time with that setup but now […]
Thank You! This method definitely makes docker us[…]
This post ^ 100% working. Thank you mate, I final[…]
How can i do upgrade from highsierra 10.13.3 to 10[…]
AMD OS X Advertisements
