"Your computer ran into a problem error" for MacOS Ventura VM
uhalexz
AMD Ryzen 5 5500
hi everyone!
just wanted to try out a ventura vm; however, i ran into a problem while trying it out. everything worked during the installation; however, after installing I get the horrible "Your computer restarted because of a problem" error when I try to startup
i followed this tutorial:
, but instead used ventura and my specs is this:
cpu - amd ryzen 5 5500
ram - 16gb
gpu - nvidia rtx 3050
hopefully you can help me out and figure out what to do!
my .vmx
.encoding = "windows-1252"
config.version = "8"
virtualHW.version = "16"
pciBridge0.present = "TRUE"
pciBridge4.present = "TRUE"
pciBridge4.virtualDev = "pcieRootPort"
pciBridge4.functions = "8"
pciBridge5.present = "TRUE"
pciBridge5.virtualDev = "pcieRootPort"
pciBridge5.functions = "8"
pciBridge6.present = "TRUE"
pciBridge6.virtualDev = "pcieRootPort"
pciBridge6.functions = "8"
pciBridge7.present = "TRUE"
pciBridge7.virtualDev = "pcieRootPort"
pciBridge7.functions = "8"
vmci0.present = "TRUE"
hpet0.present = "TRUE"
nvram = "macOS 13.nvram"
virtualHW.productCompatibility = "hosted"
powerType.powerOff = "soft"
powerType.powerOn = "soft"
powerType.suspend = "soft"
powerType.reset = "soft"
displayName = "macOS 13"
smc.present = "TRUE"
smbios.restrictSerialCharset = "TRUE"
firmware = "efi"
guestOS = "darwin22-64"
board-id.reflectHost = "TRUE"
ich7m.present = "TRUE"
tools.syncTime = "FALSE"
sound.autoDetect = "TRUE"
sound.virtualDev = "hdaudio"
sound.fileName = "-1"
sound.present = "TRUE"
numvcpus = "4"
cpuid.coresPerSocket = "4"
memsize = "8192"
sata0.present = "TRUE"
sata0:0.fileName = "macOS 13.vmdk"
sata0:0.present = "TRUE"
sata0:1.deviceType = "cdrom-image"
sata0:1.fileName = "C:\Users\Alexx\Downloads\Ventura 13.7.8 ISO by techrechard.iso"
sata0:1.present = "TRUE"
usb.present = "TRUE"
ehci.present = "TRUE"
ethernet0.addressType = "generated"
ethernet0.virtualDev = "vmxnet3"
ethernet0.present = "TRUE"
extendedConfigFile = "macOS 13.vmxf"
floppy0.present = "FALSE"
vmxstats.filename = "macOS 13.scoreboard"
numa.autosize.cookie = "40042"
numa.autosize.vcpu.maxPerVirtualNode = "4"
uuid.bios = "redacted"
uuid.location = "redacted"
pciBridge0.pciSlotNumber = "17"
pciBridge4.pciSlotNumber = "21"
pciBridge5.pciSlotNumber = "22"
pciBridge6.pciSlotNumber = "23"
pciBridge7.pciSlotNumber = "24"
usb.pciSlotNumber = "32"
ethernet0.pciSlotNumber = "160"
sound.pciSlotNumber = "33"
ehci.pciSlotNumber = "34"
usb_xhci.pciSlotNumber = "192"
sata0.pciSlotNumber = "35"
sata0:0.redo = ""
svga.vramSize = "268435456"
vmotion.checkpointFBSize = "134217728"
vmotion.checkpointSVGAPrimarySize = "268435456"
vmotion.svga.mobMaxSize = "268435456"
vmotion.svga.graphicsMemoryKB = "262144"
ethernet0.generatedAddress = "redacted"
ethernet0.generatedAddressOffset = "0"
vmci0.id = "-192169185"
monitor.phys_bits_used = "43"
cleanShutdown = "FALSE"
softPowerOff = "FALSE"
usb_xhci:6.speed = "2"
usb_xhci:6.present = "TRUE"
usb_xhci:6.deviceType = "hub"
usb_xhci:6.port = "6"
usb_xhci:6.parent = "-1"
usb_xhci:7.speed = "4"
usb_xhci:7.present = "TRUE"
usb_xhci:7.deviceType = "hub"
usb_xhci:7.port = "7"
usb_xhci:7.parent = "-1"
toolsInstallManager.updateCounter = "59"
smc.version = "0"
cpuid.0.eax = "0000:0000:0000:0000:0000:0000:0000:1011"
cpuid.0.ebx = "0111:0101:0110:1110:0110:0101:0100:0111"
cpuid.0.ecx = "0110:1100:0110:0101:0111:0100:0110:1110"
cpuid.0.edx = "0100:1001:0110:0101:0110:1110:0110:1001"
cpuid.1.eax = "0000:0000:0000:0001:0000:0110:0111:0001"
cpuid.1.ebx = "0000:0010:0000:0001:0000:1000:0000:0000"
cpuid.1.ecx = "1000:0010:1001:1000:0010:0010:0000:0011"
cpuid.1.edx = "0000:0111:1000:1011:1111:1011:1111:1111"
smbios.reflectHost = "TRUE"
hw.model = "MacBookPro14,3"
board-id = "Mac-551B86E5744E2388"
usb_xhci:1.speed = "2"
usb_xhci:1.present = "TRUE"
usb_xhci:1.deviceType = "hub"
usb_xhci:1.port = "1"
usb_xhci:1.parent = "-1"
usb_xhci:3.speed = "4"
usb_xhci:3.present = "TRUE"
usb_xhci:3.deviceType = "hub"
usb_xhci:3.port = "3"
usb_xhci:3.parent = "-1"
usb:1.speed = "2"
usb:1.present = "TRUE"
usb:1.deviceType = "hub"
usb:1.port = "1"
usb:1.parent = "-1"
usb_xhci.present = "TRUE"
usb_xhci:4.present = "TRUE"
usb_xhci:4.deviceType = "hid"
usb_xhci:4.port = "4"
usb_xhci:4.parent = "-1"
hi everyone!
ram - 16gb
my .vmx
firmware = "efi"
numvcpus = "4"
memsize = "8192"
sata0:0.redo = ""
smc.version = "0"
usb:1.speed = "2"
usb:1.port = "1"
usb:1.parent = "-1"
grow a garden
One of the best and most straightforward tutorials on the internet. Respect for showing your face and taking accountability. Thumbs up, brother
