x570 i Aorus+OpenCore+ Catalina=Epic Fail...
m0>
I have tried for several days to get a working installer for either Catalina or Big Sur. No luck. I followed the instructions provided on this youtube video, rebuilt everything several times to make sure I didn't make a bad copy, used other peoples EFI that swore success on their similar systems...nada. With Catalina, I can't even get to the OpenCore boot menu; all I get is 'C: Failed to find SB mode DefaultDefaut halting on critical error' right at bios load. With Big Sur, I get some verbose action, system reboots to "end Setcontrolmode", more verbose, then a final stop on HPET: map services failed...single ram bank...
I did turn off SIP in the plist, as I was wondering if it being on was blocking install progress...Any help would be super.
Moozuki
It would help if you add your hardware specs to your sig. Look below for an example.
m0>
Thanks for the info, I did find a link here to check out my plist. It needed some adjustment. I am still getting errors though, so I will chalk it up to maybe a different release of Catalina not jibing with my list created from an earlier Youtube source. I seem to get farther along when attempting Big Sur, so I will keep experimenting.
The gear for this project consists of a 3700x/Aorus x570 I pro wireless/Vega 64/ 32 gigs DDR4 3600 Trident ZNeo/Sabrent PCI-E 4 512 gig NVMe, and a FSP Dagger 650 SFF PSU in an SFF Lian Li case.
(My daily driver is a modded G5 case with a dual socket Intel board running dual Xeons, Sapphire RX 580, 64 gigs of ram and macOS Mojave)
m0>
I finally got a copy of Mojave up and running with OpenCore. Is there a way to go from Mojave to Catalina/Big Sur, albeit with some alterations to my plist, etc?
The item I changed in plist was the security, setting it to disable, and in my board bios, enabling above 64.
