vmware Big Sur
black.vpo1
AMD Ryzen 7 7800X3D
Hi,
i have macos big sur installed on vmware on pc - build ↓↓ . I know, I can't update big sur with my actual graphics card. If I enabled the integrated card in the cpu in the bios, could I update to sequoia without problems?
thank you
Neither your dGPU or iGPU are supported in macOS. Also the GPU when using a VM doesn't matter unless it's being passed through which VMWare cant do.
  • Wow
Reactions: black.vpo1
so the solution to install sonoma or sequoia on VM or dualboot is replace nvidia for amd rx 6600 series ?
GPU doesn't define what you can install in VMWare.
For dual booting a phyiscal install of macOS a 6600 would work on macOS yes from Monterey 12.1 onwards.
hmm, changing the gpu decrease the performance the pc in games. I think I will buy a laptop with Intel.
thanks for the answers
