Hi there, while booting into the installation USB created in macOS, I came up a problem about IONvmeController. I have installed catalina on the same computer, the NVMe driver functioned well. I am not sure if it is caused by the newly-installed HDD.
And here is the problem:
I have tried the following methods:
1.Using CtlnaAHCIPort.kext
2.Changing Misc->Security->SecureBootModel from Default to Disabled
And I tried hard to google similar situation but answers are quite helpless.
Need help
And here I attach my EFI folder here (using OC-0.6.6-DEBUG version)
You are free to use my EFI but remember to create and add your own Serial number in config.plist
And the OC debug log is also attached.
Below is my hardware list:
CPU AMD Ryzen 9 3950X 16-Core
Motherboard ASUS Pro WS X570-ACE(AMD PCI Standard Host CPU Bridge)
GPU AMD Radeon RX 5700 XT ( 8 GB / Sapphire )
Memory 64 GB ( KLEVV DDR4 3200MHz ) (16GB*4)
NVMe SSD WD WDC WDS100T2B0C-00PXH0 ( 1 TB / SSD ) * 2 (Installing on one of them)
SATA SSD WD WDC WD30EFRX-68EUZN0 (3TB / HDD) (from my NAS)
Sound Realtek @ AMD High Definition Audio
Wired LAN Intel(R) I211 Gigabit Network Connection
Wireless LAN and Bluetooth Intel Wi-Fi 6 AX200 160MHz
Need help
