Hello,
I have an LG 27 4K and an UltraFine 4k monitors.
I don't remember if ever these usb hubs are working on mac os ?
Somebody can give an adfvice.
It works perfectly on W10.
Thanks
If the USB port you connect the LG USB Hub to works in macOS there is no logical reason for them not to work. As all you are doing is connecting an external hub (matters not that it is connected to a display) to the Hack.
The 3 x USB3 ports on my Dell Ultrasharp display(s) work in macOS, I use a Type-B to Type-A cable to connect the hub to my Hack. Connecting the USB Hub via a Type-C or Type-A cable shouldn't make any difference either, as long as the port on your Hack is correctly mapped and working in macOS. It may limit the speed of the USB hub but not the ports working.
