Upgrade_B550 Gigabyte Aorus Pro (Bios: F17 (Mar 27, 2024)) | Ryzen 7 5800X3D | Merc 319 Black RX 6950 XT XFX | USBMapping via SSDT
Fooose
70
10
AMD-Hackintosh-PC with Monitor and Wi-Fi – Powerful and Ready to Use! (11.2024)​
Description:
I am offering a fully equipped high-end PC that leaves nothing to be desired. With powerful hardware and an optimized cooling system, this setup is perfect for gaming, content creation, or demanding applications. Both the CPU and GPU still have about one year of warranty remaining, giving you added peace of mind!
Technical Specifications:
  • Motherboard: Gigabyte B550 AORUS PRO AM4 (2020) – Reliable and versatile, ideal for modern gaming and work needs.
  • CPU: AMD Ryzen 7 5800X3D (2023) – One of the best processors for gaming and multitasking.
  • CPU Cooler: Alpenföhn Matterhorn Pure with 2x Wing Boost Pure Plus – Efficient and quiet cooling, even under heavy workloads.
  • GPU: 16GB XFX Radeon RX 6950 XT Speedster MERC 319 Black (2023) – Maximum graphics performance for 4K gaming and demanding software.
  • RAM: 32GB Corsair Vengeance LPX DDR4-3200 CL16 Dual Kit (2020) – Fast memory for smooth performance in gaming and productivity.
  • Storage: 1TB NVMe Crucial P1 SSD (2020) – Lightning-fast loading times and ample space for games and data.
  • Case: Fractal Design ARC Midi R2 (2020) – Sleek, spacious design with excellent airflow.
  • Fans: 5x ARCTIC F14 PWM PST (2020) – Quiet and efficient cooling.
  • Wi-Fi Module: Intel AX210 – Latest wireless standards (2.4 GHz/5 GHz/6 GHz) and Bluetooth 5.3 for fast and stable connectivity.
  • Monitor: LG LCD 24" 60Hz with Mount (2020) – Perfect addition for gaming or productive tasks.
Condition:
The system is in excellent condition. All components have been regularly cleaned and maintained. There are minor signs of use on the case that do not affect functionality. A freshly installed operating system (Windows 10/11) can be provided upon request.
Price:
€1,500 (negotiable)
A fair price for a powerful and future-proof system with high-quality components and warranty on key parts.
Why this setup?
This build offers maximum gaming performance, efficient cooling, and versatility in one package. Whether gaming, streaming, or content creation, this PC is the perfect choice!
Contact:
Interested or have questions? Feel free to reach out! A visit or test run on-site is possible. Shipping can also be arranged upon request.
Looking forward to your message! 😊
  • Motherboard: Gigabyte B550 Aorus Pro | rev. 1.0
  • Bios: F17 (Mar 27, 2024)
    Major vulnerabilities updates, customers are strongly encouraged to update to this release at the earliest. Credits to "Assaf Carlsbad and Itai Liba from SentinelOne" • Introduce capsule BIOS support starting this version.
  • CPU: Ryzen 7 5800X3D
  • GPU: Merc 319 Black RX 6950 XT XFX
  • RAM: 32 GB 3600
  • Festplatte: M2 2x2TB
  • Audio Device: ALC 1220
  • macOS Version: 13.6.3
  • SMBIOS: iMacPro 1.1 macPro7.1
  • OpenCore Version: 0.9.X
Hello, everyone, I finally got my upgraded system up and running - everything works, including (Sound,Bluetooth,CPU_Temp,etc). For all who are not so patient I provide my debug-EFI. Who still has tips and optimizations, can share them with me, especially regarding USB-mapping. So, now have fun!
My GPU works with "SSDT-6950XT-SPOOF" and WG.kext.
Best regards Fooose
LAN-Fix-Realtek® 2.5GbE LAN : open Terminal: "sudo ifconfig en0 media 1000baseT mediaopt full-duplex"
Thanks DSM2!
Update to LucyRTL8125Ethernet.kext Vers.(1.1.0d8) -->lan fix no longer required.
Bios: F15 Unfortunately, sleep does not work for me with all versions after F12. Sleep works with SSDT. Thanks to atanvarno
Major settings to be changed based on the default optimal settings:
  • deactivate I2C and ESPI (essential to solve the random freeze problem) it must be in BIOS (advanced mode) under Settings -> AMD CBS -> FCH Common Options NEW BiosVersion 14c, no longer necessary
  • if applicable, set PCIe slot to Gen4 instead of Auto (may contribute to a better stability) NEW BiosVersion 14c, no longer necessary
  • enable X.M.P. memory profile
  • disable trusted computing
  • disable wake and boot over LAN
  • enable power loading in Platform Power settings (may contribute to a better stability)
  • setup fan profiles
  • Other relevant default settings:
  • Above 4G Decoding: disabled →enabled (bootoption: ncpi=2000 removed)
  • Resizable BAR support disabled
  • XHCI Hand-off: enabled
  • HPET: enabled
  • CSM support: enabled →disabled
  • BIOS → Advanced Mode → Settings → Re-Size BAR Support, choose “Auto” (from version OC 0.7.5)
  • USB declared via DSDT by https://www.hackintosh-forum.de/user/34281-apfelnico/ (from version OC 0.7.5) until OC 0.8.4
  • USB via SSDT (SSDT-B550-PTXH-TO-XHC2, SSDT-B550-XHC0-TO-XHC) defines.(vers. OC 0.8.5)
here you will find my old configuration.
You can find all my OC releases for my board on GitHub !
My Gigabyte B550I build is on 18c and I solved sleep issues with some custom SSDT.
I looked into logs and figured out that these two devices were causing instant-wake. Thus try looking for something like this in logs
kernel: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GPP0 PT23
So when I found that, I disabled the devices entirely:
DefinitionBlock ("", "SSDT", 2, "ATNVR", "DSBL", 0x00001000)
    External (_SB_.PCI0.GPP0, DeviceObj)
    External (_SB_.PCI0.GPP1.PT02.PT23, DeviceObj)
    If (_OSI ("Darwin"))
        Scope (_SB.PCI0.GPP0)
            Method (_STA, 0, NotSerialized)  // _STA: Status
                Return (Zero)
        Scope (\_SB.PCI0.GPP1.PT02.PT23)
                Return (Zero)
Over a year later, this still works just fine.
Reactions: Fooose
Thank you for your information and help, the error looks slightly different for me.
I have also found the area in the original DSDT.
Can you advise me to understand if I have to create a separate DSDT for each address "PT21", "PT22" ...?
Or am I not understanding something?
OKAY ! ;) it works !!!
Many thanks for your help!
Reactions: atanvarno
New EFI
p.s. I have noticed that my internal sound card (Realtek ALC1220-VB) no longer works. Does anyone have any idea what the problem could be?
New EFI
I would try a different ID, there are several that can work. Reset the NVRAM after each change.
0x100101, 0x100003, layout 1, 2, 3, 5, 7, 11, 13, 15, 16, 17, 18, 20, 21, 25, 27, 28, 29, 30, 34, 35, 98, 99, 100
Reactions: Fooose
Thanks for your tip. I have always entered the "Layout -ID" and it worked, I only noticed a few weeks ago that it no longer works.
The board is the same, I just replaced the CPU and GPU a few weeks ago. I can't say whether there is a connection, but now I can't get the sound to work.
Layout ID will still work to enable sound but you may need to change the value now.
Reactions: Fooose
newEFI !
I have replaced my Broadcom WLAN card with one from Intel.
As a result, the EFI has grown a lot.
                Return (Zero)
                Return (Zero)
@atanvarno , does your EFI work with Sequioa, I have same board but sleep and audio cannot work.
Reactions: Fooose
I moved to M2Pro-based Mac mini thus not maintaining my builds anymore. Sonoma was already too much trouble to keep up.
Reactions: Fooose
Hmm, genuine Mac is the end:)
Reactions: Fooose
