Upgrade Opencore
Ejh4286
Can someone help me get a working efi for my setup? I am trying to upgrade opencore from 0.6.3 to 0.7.5 so I can try to install Monterey.
CPU | AMD Ryzen Threadripper 2970X
Motherboard | Asrock X399m Taichi
Sapphire radeon RX 580
I have a fully working 6.3 EFI in Big Sur, so far my attempts to get from 6.3 to 7.5 (or higher) have been unsuccessful. I've attached a copy of my current EFI. TIA.
Here you go. Updated to OpenCore 0.7.6 Release along with Lilu and it's plugins.
tikos
Hello there, im sorry for revive this post but... I have an Prime X399-A motherbboard.
I use your EfI and its resolve my issue for loading the bootloader.
BUT i have another issue. i can't install High Sierra because my internet connection dont work.
(its an Inte R i211 so your kext inside is good).
Can you help me to fix this ?
Thank you have nice day !
Proleme: solved -> I need to plug my ehternet during the load of boot and its work.
I have a second problem now. I have a shutdown at 2 minute remaining xD
OG Nerd
List all your system specs and we will help you build an EFI
