Tahoe 26.4 low framerate animations
murasaki
14
Ryzen 5600G
Hello! The scale/minimize animations and dragging the windows looks as if they are rendered at 60hz / fps or even lower. My monitor is set at 165hz using DisplayPort, FreeSync is dissabled, i am using WhateverGreen.kext v1.7.1d7, The GeekBench GPU score using Metal is over 100.000, so is running good, the animations seems to be rendered using the GPU acceleration as there is barely any cpu usage and the gpu freg spikes to 260mhz with around 10% utilization as soon as i move or minimize a window. I tried running some gpu demo in background to force the freg to go up to over 2000MHZ as i wanted to make sure that it is not some energy saving problem but it made no difference. The UFO Browser test shows 165Hz. I am running out of ideas. Was thinking to try moving to iMac SMB because now i am using MacPro. Did anyone faced this problem? I am a bit frustrated because otherwise the sistem is running awsome, no different than my Macbook Neo. I even had to disable The Genie effect as it was unberable to watch.
Using the iMacPro1,1 SMBIOS when running macOS Tahoe, is a very bad idea. As Apple dropped support for the iMP1,1 with the release of Tahoe. You should be using MacPro7,1 SMBIOS in Tahoe, as the AMD IGPU won’t work alongside the RX 6600 dGPU in your system specs. You have to either use the discrete GPU (recommended) or the IGPU on its own (not recommended). Stressing the dGPU will not impact the CPU in the way you are expecting, as the IGPU isn’t being called upon to assist the dGPU in the graphics processing being undertaken.
The only time you should use an iMac20,1 SMBIOS is if you are only using the AMD IGPU and do not have a discrete GPU present in the system. This will give you worse frame rates and a vastly lower GeekBench score.
When did the issue start, I.e. after a Software Update?
Which version of Tahoe are you running? It is assumed you are not running a Beta release.
Does it affect the whole OS or just specific aspects?
Have you changed, removed, added anything component wise to the case?
Have you checked the RX 6600 is fully seated in the PCIe slot and the power cable(s) are fully connected to the dGPU?
I am o Tahoe 26.4. I disabled software updater after i installed the OS. I always had the problem. It is mostly noticeable when dragging windows and with the animations, like minimising windows. Also, when I enter the Browse Time Machine, the animations are choppy. When scrolling in Safari I use Mos by caldis which is a smooth scrolling app, and it definitely feels like 165Hz, extremely smooth. It feels weird that my MacBook Neo that has a 60Hz display feels sometimes smoother. I can definitely say that the problem is software as I dual boot Ubuntu and that is buttery smooth.
What is the device-id of your RX 6600?
This should be visible in the Hackintool > PCIe tab.
Do you mean this? On the first page of Hackintool at system info it said 0x73FF1002 , In the PCIe tab I can't locate the device id.
Are these helpful?
Yes that is what I wanted to see, just to check the correct DeviceID was being used and that the IOReg Name was not missing any parts of the name.
Which version of WhateverGreen (WEG) are you using?
Are you using the agdpmod=pikera boot argument with WEG?
Do you have any graphics SSDT’s in your OC setup?
If yes, have you tried disabling it/them, to see if that makes a difference?
WhateverGreen.kext v1.7.1d7, Yes I am using agdpmod=pikera, In the ACPI folder, there are only 2 files : SSDT-CPUR.AML and SSDT-EC-USBX-AMD.aml
Actually, I think my base EFI folder is something you posted for a sort of similar pc here : https://forum.amd-osx.com/threads/h...failed-ryzen-5600x-msi-b550m.6441/#post-44215
He had a different motherbord, a 5600x instead of my 5600G and a 6650XT instead of my rx6600. So I just disabled my onboard gpu, replaced your NootRX.kext with WGE and added the pikera argument to make it to boot. Than I started with editing my specs, mapping my USB, adding sensors kext, all the serial numbers, and probably some other stuff that I cannot remember right know.
Should I try some aml files for my graphics SSDT’s ?
No don’t add any graphics related SSDT’s, they won’t help with your current issues. I just wanted to check you hadn’t already added any. As it is a common occurrence for a user to add something to fix an issue, that ends up causing more issues than it solves.
Users also forget to remove ‘fixes’ they try that don’t work, so they end up with unnecessary kexts, patches and SSDT’s in their setup.
I found another 2 small problems that I managed to isolate and fix this time and am posting about them in hope that someone is facing them :
I had random mouse freezes only for 1 second, couple of times per hour, and the problem was because of AMDRyzenCPUPowerManagement.kext and SMCAMDProcessor.kext . My guess is that there was a problem with the way it managed power states and freq. I can live without looking at the CPU Temp all day so I removed them and the freezes are gone. Also the GeekBench score are actually higher without them.
The other problem I was facing was that I connected the speakers thru the 3.5mm headphone jack on the monitor so I get audio working using the GPU Display Port. That gave me sound but some terrible background noise especially when scrolling the mouse wheel. I used a cheap 5 euro 3.5mm noise filter for an easy fix.
Reactions: Edhawk
