[Success] macOS Sequoia installed with an AMD Ryzen 9 7950x
RedLintu16
AMD Ryzen 7 7950X
I was able to finally get macOS Sequoia installed! I will include the EFI that I'm using and my full spec list as well. Keep in mind, that some things aren't really working still, but I'll update them soon hopefully.
Specs List:
AMD Ryzen 9 7950x
Motherboard: Gigabyte Aorus Elite B650
RAM: 128GB of G.Skill Trident Z Neo RGB (UGH) 6000M/T CL30-40-40-96
SSD #1: Samsung 990 Pro NVMe SSD 4TB
SSD #2: Samsung 990 Pro NVMe SSD 4TB
SSD #3: Samsung 970 Evo NVMe SSD 2TB
SSD #4: Samsung 870 QVO SATA SSD 8TB
AIO: NZXT Kraken Z AIO 240 millimeters
Case: Fractal North XL
Power Supply: Corsair HX1200
GPU: XFX Speedster AMD Radeon 6800XT with 18GB of VRAM
Potential Issues:
Sleep(?)
During start up, verbose screen will appear and then disappear after it's done loading completely. Issue is, when it's done loading completely, it'll not display anything for about thirty seconds and then it'll show the login screen. This is an issue I've always had with hackintoshing. I don't know if it's something to do with the EFI, GPU, or something else, but if someone can help me fix this, that would be awesome.
Nothing else I can think of regarding issues. If you test out this EFI and find an issue, please let me know so I can try and fix it.
If someone wants to use this without a LAN cable, please let me know and I'll try adding Wi-Fi capabilities to this EFI. As it stands right now, accessing the Internet is only doable with an Ethernet cable.
Attached in the attachments area is the EFI folder.
    EFI.zip
Consegui finalmente instalar o macOS Sequoia! Incluirei o EFI que estou usando e minha lista completa de especificações também. Tenha em mente que algumas coisas ainda não estão funcionando direito, mas espero atualizá-las em breve.
Lista de especificações:
AMD Ryzen 9 7950x
Placa-mãe: Gigabyte Aorus Elite B650
RAM: 128 GB de G.Skill Trident Z Neo RGB (UGH) 6000M/T CL30-40-40-96
SSD #1: Samsung 990 Pro NVMe SSD 4 TB
SSD #2: Samsung 990 Pro NVMe SSD 4 TB
SSD #3: Samsung 970 Evo NVMe SSD 2 TB
SSD nº 4: SSD Samsung 870 QVO SATA de 8 TB
AIO: NZXT Kraken Z AIO 240 milímetros
Caixa: Fractal North XL
Fonte de alimentação: Corsair HX1200
GPU: XFX Speedster AMD Radeon 6800XT com 18 GB de VRAM
Possíveis problemas:
Dormir(?)
Durante a inicialização, uma tela detalhada aparecerá e desaparecerá depois que terminar de carregar completamente. O problema é que, quando terminar de carregar completamente, não exibirá nada por cerca de trinta segundos e então mostrará a tela de login. Esse é um problema que sempre tive com hackintoshing. Não sei se tem algo a ver com o EFI, GPU ou outra coisa, mas se alguém puder me ajudar a consertar isso, seria ótimo.
Não consigo pensar em mais nada sobre problemas. Se você testar este EFI e encontrar um problema, por favor me avise para que eu possa tentar consertar.
Se alguém quiser usar isso sem um cabo LAN, por favor me avise e eu tentarei adicionar capacidades de Wi-Fi a este EFI. Do jeito que está agora, acessar a Internet só é possível com um cabo Ethernet.
Anexada na área de anexos está a pasta EFI.
Hi, my processor is Ryzen 9 7900, and my motherboard is a ProArt X670E-CREATOR WIFI. I tried to install Sonoma using your EFI, and during verbose mode, the screen freezes at the message "start trying to init PCI service..."
Could you help me?
Specs List:
AMD Ryzen 9 7950x
Potential Issues:
Sleep(?)
He might be able to help but he would have to rewrite his EFI to work with your board. Asus and Gigabyte 670/ 650 boards require different values to be able to boot. Without getting into to much detail you'd be better off staring here. https://forum.amd-osx.com/threads/ryzen-9000.5375/post-37239
I just to say thank you so MUCH for sharing this. I have been going at this for 2 days.
My specs are:
CPU: AMD Ryzen 5 7500F
Motherboard: TUF GAMING B650-PLUS
I believe I just had some unnecessary .asl files causing it to hang, which is where I followed your EFI.
hey guys I am finally ready to upgrade my x670E Creator build from Monterey to Sonoma. Will this EFI work for Sonoma? i feel like Sequoia is too deep into the Apple Silicone world.
I looked at the older Sonoma section, but I am already running OC 1.0.7 and worried about going back to 0.9.6.
your advice would be apreciated.
Specs List:
AMD Ryzen 9 7950x
Potential Issues:
Sleep(?)
Do not downgrade your EFI folder contents.
Your OC 1.0.7 EFI should work with Sonoma, assuming you have the latest AMD Kernel Patches in your config.plist, or at least a version of the AMD Kernel patches that includes Sonoma for the MaxKernel (23.99.99). Going by the use of OC 1.0.7 I would assume you also have the Kexts your system requires kept up to date.
If you are using a native Broadcom WiFi/BT card you will need to use OpenCore Legacy Patcher (OCLP) to get the WiFi working in Sonoma or newer.
  • You will need to run OCLP after you get to the Sonoma Desktop.
  • If you have the correct OCLP kexts and config.plist settings set in your config.plist & Kexts folder, OCLP will run the 'Modern WiFi' root patches.
  • The Broadcom Bluetooth module will continue to work, assuming you have a custom USB config that includes the USB port used by the Bluetooth device.
If you are using an Intel WiFi/BT card then you will need to update Airportitlwm.kext to the Sonoma 14.4 version of the kext.
  • You should already be using BlueToolFixup.kext and the other two Intel Bluetooth kexts in Monterey, if you have an Intel WiFi/BT card installed.
If you want to see/compare your EFI and config.plist to a similar system have a look in the Success Stories forum, where CaseySJ has added a couple of guides for X670E systems.
