Success, but with a couple of issues.....
r08ert0
Hi guys,
Can someone help me out please?
I’m struggling to get Bluetooth to work. I don’t understand how to map my USB ports.
Also, my WiFi speed is extremely slow, I do have a wired connection also but again this seems to be capped at 60mbps. I have no idea why. My ISP speed is 350mbps.
And finally, is there a way to get sleep to work.
I’ve read all of the guides, I think. Do I have to start from the beginning again and reinstall OC and Mac OS?
Thanks
Rob
Upload a copy of your whole EFI folder and I'll take a look.
r08ert0
Thanks so much Shaneee.
Try with this, be sure to add your info into PlatformInfo for the SMBios.
r08ert0
Hi Shaneee,
Bluetooth is now working, thanks for sorting this issue out for me.
I've lost a couple of USB ports and my USB hub doesn't work in any of the remaining working ports.
WiFi speed has increased to around 12mbps DL and 25mbps UL, the wired connection speed remains at 60mbps DL and 30mbps UL.
Did sleep get fixed on the new EFI? Ive not tried it yet as I didn't want to til I knew it was ready to go.
Thanks for all of your help
Rob
Can't say about sleep you'd have to test it. In your config.plist under Kernel -> Add
Disable the USBMap.kext and reboot.
r08ert0
Hi Shaneee,
I did the above, this stops the bluetooth from being available/working.
Thanks
Rob
Ok. Boot without the SSDTs I've added for USB and without the USB kext and send me a DSDT and IOReg output.
