Success build
maxhackintosh
Hello all
My build is finished now:
Motherboard: ROG Crosshair VIII Hero (WI-FI)
CPU: Ryzen 9 5950x
Graphic card: GeForce GTX 1080 Ti
SSD: Classic 1TB crucial
Storage: 4x 4TB
For me work: High Sierra 10.13.6 with latest update from appstore official:
Sound, Graphic with latest driver and cuda software,Ethernet,usb
No work: Wifi, keyboard backlights, bluetooth, cpu name info is not correct (i dont know how to fix)...
  • EFI HIGH SIERRA.zip
For CPU name add RestrictEvents.kext to your /EFI/OC/Kexts folder with a corresponding entry in your config.plist.
WiFi/BT fix depends on which card you are using, Intel or Broadcom?
You might want to have a read through this Post-Install guide, it has numerous fixes for common issues.
  • RestrictEvents-1.0.8.zip
Then you need to add the following kexts to your OC setup, assuming you are running macOS High Sierra.
  1. AirportItlwm.kext - High Sierra version of this kext
  2. IntelBluetoothFirmware.kext
  3. IntelBluetoothInjector.kext
Add these three kexts to your /EFI/OC/Kexts folder and a corresponding entry for each kext in your config.plist.
The three kexts you need are attached in the zipped folder below.
  • Archive.zip
maxhackintosh
Thanks for files, but i dont know how to add in config... Can you maybe help?
Here is my EFI folder.
Thanks sir!
maxhackintosh
Thanks, bluetooth work correct but cpu name and wifi not work for me. I have installed all correct in config and folders.
Try this EFI folder, it has been updated to use the latest AMD Kernel Patches with your 16-Core CPU.
  • EFI HS v2.zip
maxhackintosh
Thanks i will try.
For now on checker i got :
Patch
17 patches found - Did you apply the kernel patches correctly? Please review the Kernel Docs
Catalina 10.15.4 CPUFAMILY_INTEL_PENRYN patch found
Big Sur 11.3 CPUFAMILY_INTEL_PENRYN patch is missing or incorrect
I used the latest patches from the AMD-OSX/AMD-Vanilla GitHub page - https://github.com/AMD-OSX/AMD_Vanilla
The latest patches.plist only contains 17 x patches. This is completely different to the old set of patches which at one point had around 40 patches.
You can ignore the checker error, the patches are correct and the latest versions.
Try this updated OC 0.8.2 EFI, set again for your system including the Nvidia GPU.
I think the issue above was I forgot to set the SecureBootModel quirk as disabled. I left it as Default.
maxhackintosh
Thanks,give me few min and i will test. Thanks again sir
maxhackintosh
with your efi my graphic not work, wifi same problem. And now on boot i get error unsuported cpu. I dont understand now.
Ok at least it boots!
I have used a revised Nvidia boot argument which should fix the Nvidia card not working with the Web Drivers,
I have also replaced the WiFi kext with a specific one for High Sierra, and added a Max and Min Kernel setting so it only works in High Sierra.
  • EFI 2.zip
RestrictEvents.kext is missing from the Kexts folder and your config.plist. That kext is require fo fix the name (cosmetic only).
I thought you said the Nvidia graphics card wasn't working. Looks aright in the screenshot above.
The EFI below contains the RestrictEvents.kext. See what difference this makes.
  • EFI 3.zip
maxhackintosh
Again wifi and cpu name not work:
My wifi card is:
Up to 2.4Gbps transfer speed
Intel® Wi-Fi 6 AX200
2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
Supports channel bandwidth: HT20/HT40/HT80/HT160
My wifi card is:
The WiFi card driver you need is probably itlwm.kext from the OpenIntelWireless github repo but must be an earlier version compatible with High Sierra (if that's what you're using).
I provided the AirportItlwm kext for High Sierra, so it should work.
CPU name issue is purely cosmetic, but again RestrictEvenrs kext was provided in the last EFI folder so it should show correctly in About this Mac.
maxhackintosh
I will try install big sure now or latest macOS. Thanks guys for help me ♥️
