Stuck on Opencore bootmenu
blackjack1942
5
Ryzen 9 9900x
I have a problem on booting macos, I always stuck on bootmenu. After I select my bootdrive, it says OK but stuck on that.
See the attached pic.
Here's my specs
Ryzen 9 9900x
Asus TUF B650 MoBo
Asus TUF RX 7900xt
and here's my EFI
    EFI.zip
Here's my specs
Ryzen 9 9900x
Asus TUF B650 MoBo
Asus TUF RX 7900xt
and here's my EFI
Unfortunately your GPU is not supported and neither is the iGPU on the processor. If you really want to run macOS you will want to buy a support GPU. Dortania maintains a list of supported GPUs on their OpenCore Install Guide webpage.
Oh I see :( I will build a new PC just for MacOs. Do you recommend whats specs should I buy in order to run the latest macos?
Your motherboard and CPU are fine, it is just the discrete GPU that is not compatible with macOS.
Here is a link to GPU Buyers Guide for AMD dGPU's.
RX 5000 or 6000 series GPU would be best.
