Stuck at installing
shadyashraaf
I tried installing the os but im stuck at this screen can somebody help
What bootloader are you using? If it's Clover then it's unsupported, use OpenCore. If you are already using OpenCore check your config.plist file on this site, https://opencore.slowgeek.com/
I was not using opencore but I was using clover, I'll try opencore and I'll be back in a few thanks for fast reply
Please I'd like to know if my cpu is compatible to install the OS
I'm using CPU: AMD A8-7650K
Depending on your GPU yes. The integrated GPU on the CPU isn't supported.
