Stuck at "HID Legacy shim 2"
JKT01
Scotland
Hi, not sure if this is the correct place to be posting this but when selecting MacOS Installer from opencore it gets stuck at "HID Legacy shim 2" and "waiting for root device" then it shows a prohibited sign and then the graphics all get messed up.
Before i decided to post on the fourms i went through the troubleshooting guide multiple times making sure i was doing everything correctly but i have a feeling that i've misunderstood something,
- Ryzen 5 2600
-16GB Ram
-GTX 1050ti
-Gigabyte a320 - s2h (not sure if this board would even work as i've heard that hackintoshes can be very picky about hardware)
-160gb hdd
I've attatched my EFI folder incase thats needed for support.
Are you on system 15 or system 13
