i have got a problem with my efi file. Opencore Launcher shows some errors. Can u help me please?
Mainboard: MSI MPG B550 Gaming Edge WIFI, ATX, So.AM4 (7C91-008R)
Prozessor: AMD Ryzen 7 5800X 8x 3.80GHz So.AM4 WOF
Graphic: AMD Radeon 6900XT
DDR: Corsair Vengeance LPX 64GB (2x32GB) DDR4 3200MHz C16
CRUCIAL P1 1 TB, Samsung 980 500 GB PCIe 3.0
00:000 00:000 OCS: Failed to parse data field as value with type mdata and <789F70F94563> contents, context <ROM>!
00:000 00:000 OCS: No schema for KeyMergeThreshold at 2 index, context <Input>!
00:000 00:000 OCS: No schema for AppleEvent at 4 index, context <ProtocolOverrides>!
00:233 00:233 OC: Failed to drop ACPI 54445353 0000006D50757043 0 (0) - Not Found
00:265 00:032 OC: Failed to drop ACPI 54445353 0074734930757043 0 (0) - Not Found
42:761 42:496 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
42:794 00:032 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
42:827 00:033 AAPL: #[EB|H:IS] 0
42:862 00:034 AAPL: #[EB|LOG:INIT] 2022-06-09T14:01:20
42:898 00:035 AAPL: #[EB|VERSION] <"bootbase.efi 495.140.2~17 (Official), built 2021-08-30T07:02:12-0700">
42:934 00:035 AAPL: #[EB|BUILD] <"BUILD-INFO[308]:{"DisplayName":"bootbase.efi","DisplayVersion":"495.140.2~17","RecordUuid":"6B6B10D3-E712-4F5D-9988-B4A9386C79CF","BuildTime":"2021-08-30T07:02:12-0700","ProjectName":"efiboot","ProductName":"bootbase.efi","SourceVersion":"495.140.2","BuildVersion":"17","BuildConfiguration":"Release","BuildType":"Official"}">
42:970 00:035 AAPL: #[EB.CFG.DEV|!] Err(0xE) <- RT.GV booter-strict-xmlparser 7C436110-AB2A-4BBB-A880-FE41995C9F82
43:005 00:035 AAPL: #[EB|CFG
EV] r5 0x0 0x0
43:041 00:035 AAPL: #[EB|H:IS] 0
43:077 00:035 AAPL: #[EB|WL:MODE] 0
43:112 00:035 AAPL: #[EB|CFG:ARG] boot-save-log 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) default
43:148 00:035 AAPL: #[EB|CFG:ARG] wake-save-log 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) default
43:184 00:035 AAPL: #[EB|CFG:ARG] console 0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) default
43:219 00:035 AAPL: #[EB|CFG:ARG] serial 0x0000000000000001 (0x0000000000000001 < 0x0000000000000000) default
43:255 00:036 AAPL: #[EB|CFG:ARG] embed-log-dt 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) default
43:295 00:039 AAPL: #[EB|CFG:ARG] timestamps 0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) default
43:330 00:035 AAPL: #[EB|CFG:ARG] log-level 0x0000000000000001 (0x0000000000000001 & 0x0000000000000021) default
46:450 03:119 AAPL: #[EB|CFG:ARG] breakpoint 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
46:484 00:034 AAPL: #[EB|CFG:ARG] kc-read-size 0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) default
46:518 00:033 AAPL: #[EB|H:IS] 0
46:552 00:033 AAPL: #[EB|WL] 0 0 0x01 0x01 0 0x00
46:585 00:033 AAPL: #[EB|BRD:NV] Mac-27AD2F918AE68F61
46:619 00:033 AAPL: #[EB|WL] 0 0 0x01 0x01 2 0x00
46:708 00:088 AAPL: #[EB.BST.IDT|+]
46:747 00:039 AAPL: #[EB|BM] J160AP
46:788 00:040 AAPL: #[EB.BST.IDT|-]
46:827 00:039 AAPL: #[EB|WL] 0 0 0x01 0x01 3 0x00
46:866 00:039 AAPL: #[EB|WL] 0 0 0x01 0x01 4 0x00
46:906 00:039 AAPL: #[EB|BRD:NV] Mac-27AD2F918AE68F61
46:945 00:039 AAPL: #[EB|WL] 0 0 0x01 0x01 5 0x00
46:985 00:039 AAPL: #[EB.H.CHK|BM] 0x0000000000000000
47:024 00:039 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
47:063 00:039 AAPL: #[EB|WL] 0 0 0x01 0x01 23 0x0E
47:103 00:039 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
47:142 00:039 AAPL: #[EB|WL] 0 0 0x01 0x01 24 0x0E
47:182 00:039 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
47:221 00:039 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
47:261 00:039 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
47:301 00:039 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
47:340 00:039 AAPL: #[EB|H:NOT]
47:380 00:039 AAPL: #[EB|SB
] 0x0
47:419 00:039 AAPL: #[EB|LIMG
P] VenMedia(957932CC-7E8E-433B-8F41-D391EA3C10F8)/MemMap(10:100000000-100001000)/DMG_0000000027D33787.dmg/VenMedia(004B07E8-0B9C-427E-B0D4-A466E6E57A62)/HD(Part1,Sig3704F11C-3C6D-4F16-B59C-C5409190D8E5)
47:459 00:039 AAPL: #[EB|LIMG:FP] \System\Library\CoreServices\boot.efi
47:498 00:039 AAPL: #[EB|LIMG:OPT]
47:538 00:039 AAPL: #[EB.B.OBV|BM:+DMG]
47:582 00:043 AAPL: #[EB.B.OBV|BM:+ROS]
47:623 00:040 AAPL: #[EB|RPS] 0 0 0
47:662 00:039 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
47:702 00:039 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\com.apple.Boot.plist"> <"0">
47:741 00:039 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
47:781 00:039 AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
47:820 00:039 AAPL: #[EB.OPT.LXF|F] <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist">
47:860 00:039 AAPL: #[EB.LD.LF|IN] 0 1 <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist"> <"0">
47:908 00:048 AAPL: #[EB|KF] <"">
47:947 00:039 AAPL: #[EB|MBA:CL] <"">
47:987 00:039 AAPL: #[EB|MBA:NV] <"-v keepsyms=1 debug=0x100 alcid=1 slide=209">
48:026 00:039 AAPL: #[EB|MBA:KF] <"">
48:115 00:088 AAPL: #[EB|MBA:OUT] <"-v keepsyms=1 debug=0x100 alcid=1 slide=209">
48:148 00:033 AAPL: #[EB|LOG:VERBOSE] 2022-06-09T14:01:26
48:182 00:033 AAPL: #[EB.CSR.S|VAR] 0x00000040
48:216 00:033 AAPL: #[EB|OPT:BM] 0x821082
48:250 00:033 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\PlatformSupport.plist">
48:284 00:033 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\PlatformSupport.plist"> <"0">
48:324 00:040 AAPL: #[EB|B:VAw]
48:360 00:035 AAPL: #[EB.B.MN|BM:ROS]
48:399 00:039 AAPL: #[EB|WL] 0 0 0x01 0x01 19 0x0E
48:439 00:039 AAPL: #[EB.CS.CSKSD|+]
48:478 00:039 AAPL: #[EB.G.CS|-?] Ok(0)
48:518 00:039 AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1">
48:561 00:043 AAPL: #[EB.B.SBS|SZ] 739896
48:604 00:042 AAPL: #[EB|B:SHA] <bc0a873db6d0ea0e3c53e8e613a8cc781a5d3cfe>
48:644 00:039 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
48:683 00:039 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
48:723 00:039 AAPL: #[EB.WL.PWLFRTC|NONE]
48:763 00:039 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC
48:848 00:085 AAPL: #[EB.LD.LKC|R.1] <"System\Library\KernelCollections\BootKernelExtensions.kc">
51:610 02:761 AAPL: #[EB.LD.LKFS|-?] Ok(0)
51:652 00:042 AAPL: #[EB.LD.LKC|-?] Ok(0)
51:689 00:037 AAPL: #[EB|FWFM] 0x00000008FFFFFF7F
51:722 00:033 AAPL: #[EB|FWFT] 0x00000008FDAFF066
51:756 00:033 AAPL: #[EB|BST:REV1]
51:790 00:033 AAPL: #[EB|CSR:OUT] 0x00000040
51:825 00:035 AAPL: #[EB.BST.FBS|+]
51:865 00:039 AAPL: #[EB.BST.FBS|ADSZ] 0
51:904 00:039 AAPL: #[EB.BST.FBS|KSSZ] 0
51:944 00:039 AAPL: #[EB|SB:SBGMFNS] j160ap.im4m
51:983 00:039 AAPL: #[EB|RH
F] usr\standalone\OS.dmg.root_hash
52:023 00:039 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.j160ap.im4m">
52:062 00:039 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
52:103 00:040 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">
52:142 00:039 AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
52:181 00:039 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
52:221 00:039 AAPL: #[EB.B.WFDW|!WF] Err(0xE) 0
52:260 00:039 AAPL: #[EB|LOG
T] 2022-06-09T14:01:30
52:300 00:039 AAPL: #[EB|LOG:EXITBS:START] 2022-06-09T14:01:30
EV] r5 0x0 0x043:041 00:035 AAPL: #[EB|H:IS] 0
] 0x047:419 00:039 AAPL: #[EB|LIMG
P] VenMedia(957932CC-7E8E-433B-8F41-D391EA3C10F8)/MemMap(10:100000000-100001000)/DMG_0000000027D33787.dmg/VenMedia(004B07E8-0B9C-427E-B0D4-A466E6E57A62)/HD(Part1,Sig3704F11C-3C6D-4F16-B59C-C5409190D8E5)47:459 00:039 AAPL: #[EB|LIMG:FP] \System\Library\CoreServices\boot.efi
F] usr\standalone\OS.dmg.root_hash52:023 00:039 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.j160ap.im4m">
T] 2022-06-09T14:01:3052:300 00:039 AAPL: #[EB|LOG:EXITBS:START] 2022-06-09T14:01:30
