Ryzen 5 5500u help please
bigOver55
Ryzen 5 5500u
guys i am using google translate. sorry. I have a zenbook laptop. ryzen 5 5500u I want to install macos can you help me?
Where can I find the installation files?
Help me! Please. can i install xcode? It is not a problem right?
Your Asus Zenbook laptop uses AMD integrated graphics, which are not supported in macOS.
For any AMD system it is currently a requirement that it have a discrete graphics card, which can be used to drive the display in macOS. There is some development to fix this issue, but I am not sure it is moving fast or if it will ever work. Look up WhateverRed for details of this development - https://github.com/NootInc/WhateverRed
You won't be able to run macOS on your laptop due to it using and containing only an Integrated graphics card..
