Ryzen 5 3600, ASRock X570 ITX/TB3, Sapphire Nitro+ RX570, Catalina + OpenCore
atanvarno
28
Serbia
5900X
My OpenCore EFI setup along with hardware specs.
Main use for this build is Plex and other media server. It plays all DRM protected media: iTunes, Apple TV+, Plex, Netflix in Safari etc, all with hardware-acceleration.
Thus almost everything works apart from few issues which I decided to ignore.
Things that do not work:
  • Thunderbolt 3 (works fine as USB-C)
  • Sleep and wake (have no idea why, don't really care)
  • Weird watchOS SDK + Core Data issue
At the moment, I'm using OpenCore 0.5.7, Catalina 10.15.4. I keep up with releases of both Catalina and OC, fairly quickly, thus watch the GitHub repo if you want to stay up to date.
Reactions: ftln and Aluveitie
Hey! How difficult was it to replace the WiFi card? I haven’t attempted to replace mine yet. Also, is that Fenvi card just a standard dell dw1560 (BCM94352Z)?
Thanks!
Hey! How difficult was it to replace the WiFi card? I haven’t attempted to relive mine yet. Also, is that Fenvi card just a standard dell dw1560 (BCM94352Z)?
Thanks!
Not that difficult, you can see most of the process in this video. X570 heatsinks are a pain in the ass, with today's knowledge I would go for some B450 board (most likely Asus Strix ITX).
No idea about DW1560, I don't think it makes any difference what exact card it is, chip is what matters.
Thanks for getting back to me. I appreciate that video, too. I already went ahead and ordered a card, plus an adapter, because I couldnt find any m2 cards here in the UK. I just hope that the combined thickness has enough clearance underneath that metal sheath the that current card sits in!
I'm thinking the upcoming B550 (even though they will again be outdated a couple of months after their release) will be much better choice for ITX as ITX just waste much of what X570 offers, especially those chipset PCI lanes.
Why do you think that? Just the price/performance ratio?
The X570 also produces a lot more heat and almost all boards come with a chipset fan. And you pay for things you don’t or can’t use.
