rx5700xt best kexts, arguments and settings
madvinegar
116
31
28
Greece
Any owner of the rx5700xt can help please?
What are the best kexts, settings and arguments I have to set to get the most out of the card?
I seem to be getting much lower benchmark results compared to when I run the card in windows.
Thanks!
Aside from running npci=0x300 and agdpmod=pikera boot flags to get the system booting I've had no issues with my RX5700XT
What SMBIOS are you using?
What benchmarking tool are you using?
Hi, thanks for your reply.
First of all I use npci=0x3000 (not 300). Should I change it to 300...?
I use geekbench5. In windows I get a score of 76.000 and on hackintosh I get a score of only 50.000
I also get some glitches in the mouse movements.
My smbios is iMacPro1,1.
I meant 3000 that was a typo
I've got the the same iMacPro1,1 so that all sounds good..
Not run GeekBench before so I'm not going to be much help otherwise - good luck though!
