I want to share one interesting result.
If you have BISO which could setup more forced memory for IGPU, try 8G.
Then you could open the VDA acceleration. you probably would get slow loading of some software which use VDA acceleration, but it will work and never crash.
Then you could open the VDA acceleration. you probably would get slow loading of some software which use VDA acceleration, but it will work and never crash. View attachment 11590View attachment 11591
Framebuffer I use Coffee Lake - 0x3E9B0007, because I checked the specification of fake model which I use iMacPro1, 1, this IMac has the Intel UHD Graphics 630.
Just my understanding, I do not know if the logic is right.
I wasn't suggesting he use either. I know what NootedRed recommends, as I have two AMD Ryzen systems one with a Ryzen 5 5600g installed and I am currently playing with running macOS on it. I was just pointing out that his logic was flawed and why those two SMBIOS's were the main options for AMD systems. Probably could have worded the message better. I just thought that telling the OP he was talking bollox would be a bit rude!
Congratulation, can you share me your EFI Folder car i tried many to install Ventura but no success! i have R5 5600g + ROG B550 A gaming with 32 gb of ram! please
