Solved problem with hard drive
dataroot
at moment the disk on which I was going to install the system (st3320620as) began to appear, how to fix it and why did it disappear? other are shown (Apacer AS350 and ST500DM002-1BD142)
So it showed then dissapeared? From where exactly? Also please include your system specifications and add them to your signature here, https://forum.amd-osx.com/account/signature
Is SATA set to AHCI in your BIOS?
dataroot
this happened when trying to install Mac OS Mojave, 2 fails, after these two installations the disk stopped being detected in the Mac OS disk utility and the installer, disk is fully working, AHCI setted up (sorry,i have bad english)
Are you able to format it to HFS in Disk Utility?
dataroot
in macos no, but i can format it in paragon hard disk manager. system doesnt see anymore
dataroot
by the way, do u know, why i have kernel panic when i setting my cores in config?
upd: tried to install macos, can it fix?
upd2: now ( I don’t know why) Mac OS don’t load
  • Installer Log 09-13-24.txt
Try this,
dataroot
Use the EFI I sent and choose macOS Installer. Seems you've already completed the first stage of the installer.
dataroot
yes, but its not complete, check log in previus post
upd: i used efi from github when installing
upd2: in opencore no macos installer, only base system
That screenshot isn't from the EFI I sent you. That's from OC 0.9.0
dataroot
This is due to missing outdated Apple Secure Boot manifests present on your preboot volume resulting is a failure to load if you have SecureBootModel set, reason for these files being missing is actually a bug in macOS.
You're installing Catalina right? Did you download the image from Apple following Dortania guide?
dataroot
no, i used gibMacOS,bdu and transmac
