Problem install on sonoma (X570 Prime-Pro/ R7-3700X / RX6700XT)
dexter74
Ryzen 7 3700X
Hello,
I am encountering a problem when installing MacOS Sonoma on my machine.
I think my MacOS haven't Internet.
Return Code:
PKDownloadError Error 8
Console: (Install)
IFJS: Package authoring Error: Access to path : /tmp/com.apple.pkg.testing
Failed to get bridge device
OSIPredicateUpdateProduct: Incompatible App List : No Product Found
Failed to find incompatible app list on software update catalog
Failed to initialize SUMacControllerClient
Plist: the system volume wasn't found
Failed to write file <private>
No IAL Update found
started downloading com.apple.pkg.InstallAssistant.macOSSonoma
My Build:
SMBios: MacPro7,1
Core:
  • Opencore 1.0.1 + AMD_Vanilla
  • EC-USBX-Desktop.aml (ACPI)
  • HFSPlus.efi (Drîvers)
Kexts:
  • 0. AppleMCEReporterDisabler
  • 1. AppleIGB
  • 2. Lilu
  • 3. NVMeFix
  • 4. RestrictEvents
  • 5. VirtualSMC
  • 6. WhateverGreen
  • 7. AppleALC
ocvalidate:
config.plist in 2 ms. No issues found
Tree:
├── com.apple.recovery.boot
│ ├── BaseSystem.chunklist
│ ├── BaseSystem.dmg
│ └── Sonoma.txt
└── EFI
├── BOOT
│ └── BOOTx64.efi
└── OC
├── ACPI
│ └── SSDT-EC-USBX-DESKTOP.aml
├── config.plist
├── Drivers
│ ├── hfsplus.efi
│ ├── OpenCanopy.efi
│ ├── OpenRuntime.efi
│ └── ResetNvramEntry.efi
├── Kexts
│ ├── AppleALC.kext
│ ├── AppleIGB.kext
│ ├── AppleMCEReporterDisabler.kext
│ ├── Lilu.kext
│ ├── NVMeFix.kext
│ ├── RestrictEvents.kext
│ ├── VirtualSMC.kext
│ └── WhateverGreen.kext
├── OpenCore.efi
├── Resources
│ ├── Audio
│ ├── Font
│ ├── Image
│ └── Label
└── Tools
├── CleanNvram.efi
├── OpenShell.efi
└── ResetSystem.efi
I'm actuality on Linux
Your Ethernet port may not work in Sonoma. The Intel I211-AT is known to be problematic in recent releases of macOS, it will be why you are using AppleIGB.kext and not the SmallTrees kext.
If you have a USB to Ethernet adapter that might fix your issue. I know other members here have had to use the USB to Ethernet Adapter to get around this issue.
The alternative is to install a PCIe Ethernet card (Intel or Realtek) that is supported by IntelMausi.kext, RealtekRTL8111.kext (1GB) or LucyRTL8125Ethernet.kext (2.5GB card). There are plenty of these macOS compatible Ethernet cards available on Amazon from as little as £9.
Are you using the boot arg e1000=0 with AppleIGB?
